2005 F-250 SD Grill
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 513
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:4/28/2005 19:18
Hi all,
I know in the past there have been some discussions posted about after market grills and oem chrome griils installed on our excursions. I found a 2005 grill/ headlight set off an F-250 SD and was wondering if anyone knew if that set-up would work on a 2000 Ford Excursion 7.3L PSD. Thanks in advance for your replies
Eddie Henson
Posted:4/28/2005 21:18
To upgrade to a 2005 grille you'll need the header panel for the bottom of the grille to attach to,the 2005 grille is too tall for the 99-2004 bumper so you'll need the 2005 grille assembly.
The 2005 headlights I believe will bolt up to the 99-2004 headlight buckets but not 100% positive.
For the new headlights you'll need the upgraded headlight pigtails.
Friend of mine down in Beaumont upgraded his front end to the 2005 and his truck is a 99,here's a PHOTO of the completed work
It can be done for sure but it's just a little work.
2005 F-250 SD Grill
