Hey, guys help me on this wiring deal, I am begging you..........
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 438
Ozzie
• Kansas City Mo., MO, USA
• Registered on 5/20/2005
• 15 posts
Posted:5/22/2005 07:36
I need your help in selecting the wire under the dash I can tap into to power the 18 amp compressor for my air pump. I can use a realy so the coil doesn't pull any amps. if needed, but need to know which wire will be hot only when key is on.
2001 Excursion Limited 4x4 V-10
Sorry to be so dramatic, but I'm running out of time.
(First post below)
I have everything wired up, but I need to switch the hot wire so I only have power when the key is on.
Also, I need to tap into another convenient location for my tranny gage light.
Could you help me locate the places to tap into?
Thanks, Oz.
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:5/22/2005 21:30
sorry bud, I can't think of any wire color of hand for the quick fix. But what I would do is look at the radio controls for a tap. check it out with a volt meter to find the one that is hot with the key on and hook it up that way. with a relay you can't go wrong. The radio fuse also has a little more to play with then the other fusses.
Yahoo IM - kingsuv00
Ozzie
• 15 posts
Posted:5/22/2005 22:42
Thanks, Bill
I will look into that tomorrow. We are headed to Colorado from Kansas City, and I want it to work.
We are pulling our 30' 10K # TT out there.
I changed out the light duty air lines for my on board air, and air horn today, had to silver solder some 1/4" copper to 3/8" hose barb fittings for the air horn, I ran all 3/8" I.D. air lines.
I have an access for my female quick disconnect and a pressure gage in the spare tire and rear A/C enclosure. (I have level-air bags for the trailer wheels.)
Take care, Oz.
