4x4 Front Wheel Bearings
Thread Statistics:     Users to Post: 4   |   Total Posts: 9   |   Total Views: 2454
Richard Smith
• Knoxville, TN, USA
• Registered on 10/4/2003
• 104 posts
Posted:5/30/2005 12:15
Anyone have experience adjusting and re-packing 2003 4x4 Excursion front wheel bearings?
Posted:6/1/2005 10:47
Sorry for the delay in my reply
I have the complete instructions on the R&R with specifications on my laptop at my Dallas Texas home but am away in California on business so if you can hold out another week week and a half I can forward the how to when I get back
bigfoot567
• Fort Worth, TX, USA
• Registered on 3/18/2005
• 55 posts
Posted:6/1/2005 13:59
Bill if you could either post those detailed instructions and/or email them to me I'd sure appreciate it.
Bill M
Richard Smith
• 104 posts
Posted:6/1/2005 16:21
Me too!
Posted:6/1/2005 23:38
It'll be no problemo to copy/paste em here in this thread but it'll be after we get back from the west coast some time after the 7th of June if ya'll can hang on till then
Richard Smith
• 104 posts
Posted:6/13/2005 21:09
Investigations I have done with a Ford dealer and an engineer at the axle Manufacturer reveal that no added lub or adjustment is required prior to 100k miles. Off road and axles that get submerged (sp? ie:under water) may need special attention.
The bearings in the hub are greased and sealed and should be serviced as an assembly and the needle bearings should get grease any time the hub is pulled out - hopefully not before 100k.
I will be looking for bearing numbers and will try to just replace the bearings when needed.
Posted:6/13/2005 21:57
Richard I totally spaced out you needed the how to on the bearing re-pack,did you still want me to post em up or you good?
Richard Smith
• 104 posts
Posted:6/14/2005 21:00
Bill,
I don't need instructions on how to re-pack spindle bearings of the conventional Timken tapered bearing type with tabbed washers or cotter pins.
My Excursion is a 4x4 with a Model 50 Dana Front Axle. These axles have a non-adjustable set of sealed bearings in each front hub and Ford says you must replace the entire hub to service the bearings. I think we can replace just the bearings if we can get the bearing data before we pull the hubs off the truck.
The "needle bearing" is just a cartridge type bearing that holds the axle shaft in place at the end of the axle housing just behind the hub. I don't need info on these bearings.
Why pay $300 for each hub ???? Your comments would be appreciated.
edited 6/15/2005 16:23
James Stohrer
• Arlington, WA, USA
• Registered on 1/4/2002
Posted:6/15/2005 08:48
I did have to go through getting my hubs changed to the tune of $500.00 per wheel. I was out on detachment and my Wife had it done at Schwab. In my initial investigation the guy at the ford parts counter said you could get the number off the bearing punch out the old and press in the new. I am kind of glad my Wife took it in, I wouldn't have but since she did.....
I have had my X up to the running boards in salt water , probably why it did that, and I would be interested to know how to grease those bad boys so I don't run into the same problem.
Jesse
00XLTDSCMTKNR9000
