Excursion door keypad code reset
Thread Statistics:     Users to Post: 7   |   Total Posts: 8   |   Total Views: 14624
bigcahunaus
• South, FL, USA
• Registered on 9/16/2005
• 17 posts
Posted:3/3/2006 15:49
Has anyone bought a used X and able to find a way to reset the door keypad code? Some say that the factory code is hidden on the X, does anyone know where? Also the dealer says you have to show up with the Title and the vehicle in order for them to pull the factory code and charge you a fee for it. Does anyone have information?
2001 Excursion Two Tone XLT / 6" Procomp Lift / AirHog Filter
Eddie Henson
• Cordova, TN, USA
• Registered on 12/8/2004
• 122 posts
Posted:3/3/2006 15:55
Don't know where to find the keypad code. Wne to a local dealer when I first got mine to get an extra key made and had them pull up the entry code while I was waiting. No charge for the entry code, extra key was like $25. All I showed was a copy of my registration that I normally keep in my glove box. Hope this helps.
Eddie Henson
Posted:3/3/2006 15:58
Like Eddie said,just drop into the dealer with registration in hand and they may or may not charge you depending if you're a return customer or have connections there.
jxm71
• Bel Air, MD, USA
• Registered on 1/26/2006
Posted:3/6/2006 09:14
bigcahunaus -
Send me an email to [email protected]. I have a PDF telling you how to find it. It's on the X's PCM. It worked for me on my 03. I used a small "lipstick" style video camera because of all the sound deadning material under my dash. Anyone else who needs this info, please contact me.
PS - I did pay for this info, but I am providing free of charge.
Jason
03' X PSD EB
edited 3/6/2006 09:36
bigcahunaus
• South, FL, USA
• 17 posts
Posted:3/6/2006 23:01
thanks all for the information.....
Matt Cawson
• Caledonia, MI, USA
• Registered on 10/20/2004
• 82 posts
Posted:3/7/2006 07:28
The elusive vehicle security module is no where to be found on my '01. Had the dash apart and I was twisted around up in there like a pretzel with no such luck. Found a dealer through a connection that will do it for me free of charge so that's where I'm going If anyone else has had success on their '01 PLEASE let me know. It would save me a 30 minute drive to the dealer if I can get it.
cpditty
• Rogers, MN, USA
• Registered on 3/27/2006
• 10 posts
Posted:3/27/2006 16:26
Once you get the code, does anyone know how to change it? I thought I read somewhere that you could change the code as long as you had the original.
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:3/27/2006 18:32
You can not change the factory code, it is permanent. You can add a second code, but the factory code will continue to operate the locks.
This is from my '00 Owners Manual....
Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located on the owner’s wallet card in the glove compartment. ....... Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase it in favor of the new code.
//bruce
edited 3/27/2006 18:43
