60K service
Thread Statistics:     Users to Post: 3   |   Total Posts: 6   |   Total Views: 581
Jetfixr
• Orange County, CA, USA
• Registered on 1/27/2002
• 45 posts
Posted:4/25/2006 10:50
My Ex has finally reached 60K. I am replacing the oil, coolant, tranny oil and air filter. When is the best time to change the factory spark plugs? Is there anything I am missing? I don't have alot of time, so I will do a few things each weekend until I'm done.
Summer is coming so I am also changing the heater valve to the Diesel-site valve and insulating the A/C ines. Did I mention I'm doing the dor locks also? My primary vehicle(Camry) has met it's demise and the Ex is coming off the bench. I hace to fix all the things Ive been putting off.
Jerry
6.8L V-10
2000 Excursion Xlt 4X4 6.8L, 4.30LS, Grey Leather, RS9000's, Hellwig swaybar, 10.4" video w/vcr.
Posted:4/25/2006 12:11
Plugs are supposedly good till 100K. Wouldn't hurt to swap them now. That way you'll know you've got them torqued properly.
Plugs are cheap but it's a PITA to change those in the back. However, knowing your ride is at 100% is a feeling that is usually worth the busted knuckles.
Posted:4/25/2006 12:13
Odd...with gas prices here ($3.57) our Excursion is parked as much as possible. Never thought someone would put one INTO service.
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:4/27/2006 05:42
Jerry
I just had my plugs replaced at 80K. I have the extended warranty and had the dealer replace them. I told them that way if it blows a plug out of the aluminum head in 20K, they get to replace the heads!
Good luck!
David
edited 4/27/2006 05:43
Jetfixr
• 45 posts
Posted:4/27/2006 13:38
Spark plugs. Do you have to remove the fuel manifold to access? I haven't tried to change them yet.
I had to go out and get a tool for removing the fuel filter. I tried to get it out first, then after a few minutes of tugging on the fuel line, I recalled reading about a Ford removal tool. So I started researching and also found out I should bleed the pressure from the line. That will be next weekends goal, along with the coolant jobs.
I think I will replace the thermostat while I am changing the coolant. I had one stick on my toyota, cost me a head gasket!
The door locks are easy, after you finish the first.
Jerry
Posted:4/28/2006 12:04
To replease the fuel pressure just pull the fuel pump fuse with the truck running. When it dies; no more pressure.
Sparkplugs DO NOT require manifold removal but will require a U-joint attachment for your socket set.
60K service
