Any other suggestions on rotors other then ART?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1170
poormonkey
• Chicago, IL, USA
• Registered on 7/27/2004
• 59 posts
Posted:9/10/2006 17:29
Well, not to be cheap, but I just put new Dueler Revo tires on the Excursion, I am about to change out the upper and lower ball joints. I need to replace my rotors soon, and I have read the forum, and the budget is kind of tight at the moment. Everyone suggests going with the ART rotors. But, I was wondering if there is another brand that is decent and a little easier on the old pocket book? I figured while the front ball joints are being replaced, I might as well do the rotors and pads as well on the front. Anyone ever used any of the rotors offered from Summitracing.com on their Excursion?
PSR-8586PSR - $125.95 Brake Rotor, Slotted, Iron, Silver Cadmium Plated, Right Front, Ford, Excursion/ Super Duty Pickup, Each
PSR-8586PSL - $125.95 Brake Rotor, Slotted, Iron, Silver Cadmium Plated, Left Front, Ford, Excursion/ Super Duty Pickup, Each
PSR-8571PSL - $139.95 Brake Rotor, Slotted, Iron, Silver Cadmium Plated, Left Rear, Ford, Excursion/ F-250/ F-350 Super Duty, Each
PSR-8571PSR - $139.95 Brake Rotor, Slotted, Iron, Silver Cadmium Plated, Right Rear, Ford, Excursion/ F-250/ F-350 Super Duty, Each
HWK-HB302P-700 - $89.95 Hawk Performance HP SuperDuty Brake Pads
HWK-HB303P-685 - $70.95 Hawk Performance HP SuperDuty Brake Pads
They also have Iron ones and ones that aren't slotted that are even less money. Any thoughts/feedback?
2002 Excursion 4x4 7.3L
Hawkeyes
• St. Paul, MN, USA
• Registered on 12/3/2004
• 43 posts
Posted:9/13/2006 03:00
Try the SP Performance brand or just buy the Performance Friction 2-piece fronts from the same website. Then make sure you replace the caliper pins with the newest revision from Ford - 2C3Z2C150AA. Here's how to tell what you have and what you need...
http://community.webshots.com/album/63633281xQgesI
While you are at it, hone out the holes the pins slide through with a drill, wood dowel with emery cloth. It needs to be shiny and smoothe in there so the pins move freely.
The 2-piece 'floating' rotor will eliminate any pedal pulsation. Try the Porterfield carbon-kevlar pads. They are aggressive, but wont eat your rotors - also shed heat like crazy (no fade after repeated hard stops) and are low dust.
Get rotors here:
http://www.nationalfleetparts.com/performance_friction_2_piece_floating_rotors.htm
Hawkeyes
