Help needed on suvlight fix for high beams staying on
Thread Statistics:     Users to Post: 3   |   Total Posts: 10   |   Total Views: 935
Rick Beaupre
• Narragansett, RI, USA
• Registered on 3/4/2004
• 12 posts
Posted:10/21/2006 10:10
I've recently upgraded my lights to Sylvania Silverstars and installed the dual suvlight harness. Works great except for the high beams staying on. I went on the suvlights web site and found the fix but don't quite fully understand. They mention removing the fog lamp relay from the fuse panel under the hood. According to the Ex manual, mine is located under the driver's side dash. The relay is #43. Suvlights is referring to a pin #86 which you have to bend or cut. They also make mention of soldering a ground wire to this pin and connecting it to a chassis ground. I'm a little confused on what they are talking about here. How do you solder a ground wire to a pin that has been cut or removed? I'm opting for the option of keeping my fog lights on while my high beams are on.
If some of you could help clear this up I would be eternally grateful. BTW, this is a great forum and I enjoy visiting it often. Since purchasing my EX back in 04 I have made a few of the recommended upgrades and have been very pleased. Keep up the good work and thank you for your time and efforts on keeping up this great resource.
Sincerely,
Rick Beaupre
Posted:10/23/2006 18:36
Hi Rick...
I too had issues with suvlights and they were FAR less than helpful...
I considered it an $58 lesson and ordered elsewhere !
Rick Beaupre
• 12 posts
Posted:10/23/2006 18:51
Hey JohnBoy,
Thanks for the reply. I paid $118 when all was said and done - ordered the double harness. Anyway, I'd hate to eat that. I'm going to contact them tomorrow. I found their customer service less than friendly during my first go around. I figured I would wait and see if anyone here would be able to help me out in the mean time before calling them back. Who did you finally order yours from?
Rick
Posted:10/24/2006 05:50
http://gosracing.com/inc/sdetail/1983
and have heard mixed reviews on the double harness... so I got the single...
good luck...
edited 10/24/2006 05:52
Rick Beaupre
• 12 posts
Posted:10/24/2006 19:56
Thanks JohnBoy. I spoke with suvlights today and I think I've got the fix. The double harness they sell is wired differently than what an Ex needs. You have to switch the ground wire (at the end of the receptacle with another wire in the middle), the old cut and splice routine. I'm going to do it tomorrow and hopefully it will solve the problem. [img]
Rick
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:10/25/2006 00:04
mind if you guys post pics or some links?
I have this same issue and have been too lazy to go and fix it cause 99% of my driving is day time. But now that it has been brought up I feel the need to fix it
Yahoo IM - kingsuv00
Rick Beaupre
• 12 posts
Posted:10/25/2006 12:25
Well... did the fix and it works. I'll try and get some pics soon. It's a pretty easy fix. The old cut and splice. What you need to do is when looking at the back of the orange and blue sockets, the white and black wires need to be switched. The black wire (ground) needs to be in the center and the white needs to go on the outside. I had a heck of a time getting those wires out of the sockets so I just cut and spliced. Make sure you do it on both the orange (2007) and blue (2004) sockets that came with the harness.
Now I need to figure out how to keep the fog lights on with the high beams. Possibly a bridge wire? If anyone has been able to do this please let us know.
Rick [img]
Posted:10/25/2006 18:43
Cool Beans - glad u got it fixed...
too bad they dont know that wen you order it for an excursion, that u intend to PUT it on an excursion
And that reminded me I had to do something similar on my first single set I got from them for the 03 !
but they had me take the connetor apart and switch the leads.... the splice and dice is probably better because u can seal it once done...
youd' be suprised how much water gets on those connectors
edited 10/25/2006 18:44
Rick Beaupre
• 12 posts
Posted:10/25/2006 19:26
That reminds me. I need to tape up those connectors to prevent future water damage. I should probably get the relays mounted as well. Right now I just stuffed them into the open spaces between the batteries and front quarter panels. I was careful though to make sure they were facing up to allow for any water that did get in to not get into the relays themselves. Thanks JohnBoy for the reminder!
Posted:10/26/2006 22:12
quite welcome !
might just put some silicone on it...
