Home/ Forums/ Car and Truck Make and Model Specific/ Bronco, Bronco II/ 1995 351 motor problems
Bronco, Bronco II
6 posts 5 contributors 4,825 views
19
1995XLTOP
Oct 29, 2006 at 7:35 PM
New to post but I have read the site for a while now.
I have a 1995 XLT with the 351. Only has 112,000 miles on the motor.
The thing runs awesome and fast on the street and in the trails but when I am going up a large grade the motor bogs down and starts to make a knock sound and even sounds like it's backfiring through the intake.
So far I have changed the plugs, added a K&N filter kit, Flowmaster, Throttle body spacer and a MSD coil.
Like I said, It runs awesome all the time EXCELT for the grades.
This weekend while out in the desert I had it in 4high and in first gear going through some sand and it boged down and started that backfire thing.
anyone have a clue what could cause this? I just dont have any power at low end on grades or off road. When I am going slow and crawling I have a ton.
Stock size tires (31's) and 3.73 gearing.
No check engine light that comes on when this happens.
Someone help me?
Thank you
19
1995XLTOP
Oct 29, 2006 at 7:42 PM
Also like to add that I have tried putting 91 fuel and also 87 and it does the same thing no matter what gas I put in it.
CO
countryboy141
Apr 7, 2008 at 9:35 AM
HEY JUST A THOUGHT FOR YA TAKE IT IN TO A DEALERSHIP OR A FRD QUICKLANE AND HAVE THEM RUN A POWER INJECTION FLUSH, AND SCOPE AND SCAN YOUR ECU OH AND WHEN WAS THE LAST TIME U HAD YOUR TRANS SERVICED
GR
grandpagak
  • Member since Jan 2009
  • Laporte, MN, USA
Jan 31, 2009 at 10:10 PM
sounds like timing could be the culprit.
TR
Treader
Jul 15, 2009 at 9:32 PM
You might want to check your distributor for worn out bearings. I've seen distributor shaft play cause your problem. Just a thought
Treader
