Large Turbine tubes
Thread Statistics:     Users to Post: 3   |   Total Posts: 6   |   Total Views: 584
speckfisher
• Missouri City, TX, USA
• Registered on 2/2/2007
• 15 posts
Posted:2/19/2007 20:11
The 2 large steel tubes that are on the lower sides next to the 2 sides of the radiator seem to be leaking oil at the rubber coupling . Does anyone know what those rubber pieces are called?
Also the 2 trans. lines going to the cooler is one a pressure line or can they be replaced with just reg. line and clamps since they are crimped.
aklim
• Hartford, WI, USA
• Registered on 2/20/2006
• 133 posts
Posted:2/19/2007 20:47
Those are the tubes to the intercooler. The oil from them comes from your crankcase. See the link as a way to fix it.
http://www.ford-trucks.com/forums/469390-did-the-ccv-mod-awhile-ago-now-some-questions.html
Posted:2/19/2007 23:40
Here's an Excellent Article I co-authored here on Ford Excursions,check it out
Here's Another well done Article
edited 2/19/2007 23:40
aklim
• Hartford, WI, USA
• 133 posts
Posted:2/20/2007 06:41
Pay attention to the direction of the insert in the exhaust pipe as if you get it wrong, it might cause pressure in the crankcase.
http://www.ford-trucks.com/forums/showpost.php?p=3481404&postcount=22
Posted:2/20/2007 07:56
Has to be done at a 45 degree angle as best as possible when welding the bung onto the exhaust pipe. I hope to get that done in the spring
aklim
• Hartford, WI, USA
• 133 posts
Posted:2/20/2007 07:59
That is what I did. First time I had the angle of the pipe at 45 but opposite since I "knew" better. That proved to be a mess. 2nd time I did it the way it should have been and when I stuck the smoking hose to it, the exhaust clouded up a little and when I removed it, it cleared up. Then I knew it was done right.,
Large Turbine tubes
