Blower motor problem
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 1118
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:4/3/2007 07:18
I came out to a dead battery this morning. I guess I should buy a new one, since this is the original and is seven years old and 100K miles. But a new one won't fix this problem.
What I discovered is that the blower motor was running, even with the keys out of the ignition. If I turn the heater control to off BEFORE I shut off the truck, the blower shuts down. But if I don't turn the heater control to off, the blower will continue to function when the truck is off, regardless of what I do to the heater control. It did rain yesterday, so it's possible that there is a leak somewhere. But the windshield hasn't been touched in five years, so unlikely that it's leaking now. The only other symptopm is a sporadic loss of radio speakers. All radio/CD controls work properly, but the speakers will cut out for a few minutes and then come back.
I'd check my wiring diagrams, but they are at home. Anyone have any thoughts?
//bruce
Superdogsteve
• Katy, TX, USA
• Registered on 5/18/2005
• 20 posts
Posted:4/3/2007 09:18
The vary same thing happened to me and after the dealer replaced the whole climate control unit and wiring harness, they decided it was a bad relay that controls the blower motor.
I hope that gives you another option!
2005 X Limited 6.0L stock
Lead, Follow, or Get out of the way!
rozett
• 163 posts
Posted:4/6/2007 19:11
Steve, that did the trick! Thank You!
Now, maybe I can get another seven years out of battery.
//bruce
shiepo
• carson, CA, USA
• Registered on 6/23/2011
• 75 posts
Posted:8/20/2011 00:39
I came out to a dead battery this morning. I guess I should buy a new one, since this is the original and is seven years old and 100K miles. But a new one won\\'t fix this problem.
What I discovered is that the blower motor was running, even with the keys out of the ignition. If I turn the heater control to off BEFORE I shut off the truck, the blower shuts down. But if I don\\'t turn the heater control to off, the blower will continue to function when the truck is off, regardless of what I do to the heater control. It did rain yesterday, so it\\'s possible that there is a leak somewhere. But the windshield hasn\\'t been touched in five years, so unlikely that it\\'s leaking now. The only other symptopm is a sporadic loss of radio speakers. All radio/CD controls work properly, but the speakers will cut out for a few minutes and then come back.
I\\'d check my wiring diagrams, but they are at home. Anyone have any thoughts?
i too have the blower motor problem and it came this one I was told that in order to fix my blower motor that would only work on the highest setting I needed to purchase a Blower Motor Resistor, which is correct for Pathfinders that have a manual A/C system however on my pathfinder that has the Automatic A/C it is a whole different set of problems. I had alot of problems finding the blower resistor on my pathy because it doesn\\'t have one. any help on this one?
