Air Bag Pressure
Thread Statistics:     Users to Post: 3   |   Total Posts: 6   |   Total Views: 821
RedLineX
• Dallas, TX, USA
• Registered on 5/1/2006
• 27 posts
Posted:4/19/2007 16:03
Hey guys, I just installed the Firestone Ride-Rite air bags in my 05 X. I have been keeping an eye on the air pressure to make sure it stays above 5PSI. But I seem to be loosing a few pounds of pressure each day. I am thinking some of the lose is due to the fact that I keep checking it since some air escapes every time I check it.
Those that have air bags, do you notice any air pressure loss? I have checked the lines for leaks and I even tightened up the valve that goes in the air bags. I just can't locate any other reason for the pressure loss.
RedLineX
Cobra427
• Fremont, CA, USA
• Registered on 1/24/2003
• 37 posts
Posted:4/19/2007 17:40
I notice very little pressure loss, and the pressure that it does loose is similar to the pressure that a tire looses. BTW, I'm running 20lbs unloaded.
Posted:4/19/2007 19:53
I use a sprayer bottle filled with water and a teaspoon of baby shampoo mixed in then spray on the air pressure line connections to reveal the leak/s.
RedLineX
• Dallas, TX, USA
• 27 posts
Posted:4/20/2007 09:24
Does that seem a bit stiff? I like the extra stability the air bags provide to the rear end but it really seems to get bouncy back there at the higher PSI. I keep the pressure down between 10 - 5 PSI and that seems to help.
Thanks for the input
RedLineX
RedLineX
• Dallas, TX, USA
• 27 posts
Posted:4/20/2007 09:27
Yeah, that sounds like a good idea. I checked it this morning and it looks like tightening the valve in the air bag may have done the trick. If not, I will try your suggestion.
Thanks for the tip!
Cobra427
• Fremont, CA, USA
• 37 posts
Posted:4/24/2007 16:34
RedLineX
Actually, I found her to be more bouncy at 5 to 10lbs, than at 20lbs, where she's feels more solid and secure. In the back, she's also got Ken's Radius bars, a Hellwig sway bar and Edlebrock shocks. Tires are Yokohama Geolanders - 285-75/16 - Load Range D - filled to 60lbs on all fours.
Air Bag Pressure
