New Ford Uncut/unprogramed Pats Key
Thread Statistics:     Users to Post: 1   |   Total Posts: 1   |   Total Views: 1074
4Lance
• small town, XX, USA
• Registered on 6/30/2007
• 22 posts
Posted:10/28/2007 17:37
: 1998-2002 Crown Victoria
: 2000-2003 Excursion
: 1997-2002 Expedition
: 1998-2001 Explorer
: 1999-2003 F150
: 1999-2000 Ranger
: 1996-1999 Taurus
: 1999-2000 Windstar
: 1997-2004 Mustang
20$ shipped using PayPal
This is for a FORD pats keys. brand new and uncut. If you go to the dealer to buy this key you will spend 5 or 6 times more then you can get it from me. . This key is solid black.
FOR THIS CAR YOU NEED 2 WORKING KEYS TO PROGRAM MORE KEYS YOURSELF. IF YOU ONLY HAVE ONE WORKING KEY THEN YOU WILL HAVE TO HAVE THIS KEY PROGRAMED BY THE DEALERSHIP OR A LOCKSMITH BEFORE YOU CAN PROGRAM MORE KEYS YOURSELF.
PATS 2 And 3 Programming Procedure
1. Place first already programmed key in the keyway. Turn the ignition from OFF to ON(RUN) for at least 1 second and then switch to OFF.
2. Within 5 seconds, insert the second already programmed key in the keyway. Turn the ignition from OFF to ON(RUN) for at least 1 second and then switch to OFF.
3. Within 10 seconds of turning the ignition lock cylinder to OFF, insert the new key into the keyway. Turn the ignition from OFF to ON(RUN) for at least 1 second and then switch to OFF.
The theft indicator light should go on for three seconds, after which the key will start the vehicle. Repeat this process, from the beginning, for each new key to be programmed.
