Changed Fan Belt, Now I have a Vibration.
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 615
slant7
• Phoenix, AZ, USA
• Registered on 11/15/2007
Posted:11/15/2007 15:08
After I changed the Belt to a Gatorback belt, I had marked the idler pulley with a marker; it has moved a bout 1/4 inch to the tighter position. Looking at it it moved to the right. I now have a small vibration. Could it be the different surface from the belt? And is the smooth pulley on top supposed to move slightly back and forth at idle. Because it is. The vibration is not constant but noticeable.
Oh by the way its a 2001 Excur. 7.3L Deisel
edited 11/15/2007 15:11
Posted:11/17/2007 08:03
If this had happened to me, the first thing I'd do is reinstall the old belt and see if the vibration goes away. Have you tossed out the old belt yet? If the vibration remains while using the old belt, the problem is elsewhere. If the vibration goes away with the old belt, then you have an interesting problem which I cannot diagnose from here.
EDIT TO ADD: Welcome to the X-Files!
edited 11/17/2007 08:04
slant7
• Phoenix, AZ, USA
Posted:11/17/2007 23:23
Yeb, your right. I reinstalled the old belt. The vibration is gone. I will try to find a different belt. Thanks for the help.
Slant
darrell g
• detroit, MI, USA
• Registered on 12/6/2004
• 9 posts
Posted:11/19/2007 15:30
just a thought i think the belt is directional could it have been reversed ? again just a thought I didn't think putting back on the old belt would have helped, good luck
