Rear Seal leak
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 815
Rameses
• High Point, NC, USA
• Registered on 12/30/2007
• 16 posts
Posted:9/3/2008 12:30
Alright Excursion brothers I noticed a little oil in the Garage so I took it in and it looks like a rear seal leak. Is this common @ 60K miles (7.3 PS)?
Also is there anything that would have caused this?
Is there anything i need to look out for when I take this in for repair next week?
GO Tarheels!
7.3L TD Limited
Borla dual exhaust
Banks stage 1 kit
Banks pod guages
Banks Brake system
Banks Ram AIR
18'' chrome wheels and Nitto Grabber tires
Custom lower fascia
Helwig bar
White Knights rear light kit
ChuckNorris
• bryceville, FL, USA
• Registered on 10/4/2008
• 8 posts
Posted:10/4/2008 06:38
It is a rare occassion when the rear seal leaks, not to say that it does not occur. However I would encourage you to check a more common leak in the intake valley, grab a flash light look and see if there is any oil in the valley between the heads. If this is the case you my have a High pressure oil leak whether it is a pump, a pressure line or an O-ring the oil will accumulate in the valley and run down the back of the block , giving the impression of a rear main leak.
Rear Seal leak
