short79572
staten island, NY, USA |
Registered on 8/7/2005 |
12 posts |
Posted:3/6/2009 17:08 |
hi every one i have a 2001 ford excursion V10 it has about 93thou on the clock i was just recentley driveing the car and it felt like it was missing in a cyl like a coil pack was bad the check engine light came on and i got a code of P0175 which means lean in bank 2 i have checked mass air, injestors is there any one out there that can give me any more info thank you so much |
The Big Island, HI, USA |
Registered on 1/5/2002 |
1,048 posts |
2 |
Posted:3/12/2009 04:45 |
Check the hose to the PCV. It can crack at the elbow and set a lean code.
short79572
12 posts |
Posted:4/14/2009 20:18 |
nope that not it it is wired it feel like i get on the highwat and it like a coil pack kicks on and off i just replace all the coil packs and i get the same thing p0175 |
 |  Subscriber since 11/23/2003 |
Newport News, VA, USA |
Registered on 7/15/2003 |
1,110 posts |
Posted:4/18/2009 09:12 |
If the air-fuel mixture is becoming lean, then the fuel flow must not be up to snuff. When's the last time you changed the fuel filter? And that reminds me that I need to change mine. |
1,048 posts |
2 |
Posted:4/18/2009 22:47 |
Computer controlled engines we will usually only run lean if there is an unmetered air leak or a faulty sensor. A plugged up fuel filter will crreate driveabilty issues but the PCM will adjust to mixture.
1,110 posts |
Posted:4/19/2009 07:58 |
| Quote: | | Computer controlled engines we will usually only run lean if there is an unmetered air leak or a faulty sensor. A plugged up fuel filter will crreate driveabilty issues but the PCM will adjust to mixture. |
Yes, I agree, but the PCM can only adjust for so much. Each sensor in today's engines has an operating range in which it can provide readings to the PCM. Even the PCM will only accept readings within certain ranges. Go outside the allowable ranges ... go byond the ranges calculated by the design engineers (usually due to a mechanical problem) ... and the PCM cannot adjust, and though it should go into "limp mode," it may sometimes throw some codes unrelated to the source of the problem.
A vacuum leak is indeed a possibility. Another reason I tossed out the fuel filter idea is because that's an item frequently forgotten, and could be an issue on a higher mileage engine. I had forgotten mine, and this thread reminded me that I should change mine. |
short79572
12 posts |
Posted:5/13/2009 15:23 |
i changed the fuel filter and still the same thing i have to search for a vacaume leak now wish me luck |
dnevins
 Subscriber since 12/29/2009 |
San Diego, CA, USA |
Registered on 12/28/2009 |
340 posts |
For the next V10 owner who finds this, and for short79572: check the exact code number, because P0175 isn't lean. P0175 is "System Too Rich, Bank 2." Lean on bank 2 is P0174. They send you in opposite directions, so it's worth reading the code again with the scanner's own description.
On the 6.8 V10, bank 1 is the passenger side (cylinders 1 to 5, front to back) and bank 2 is the driver side (cylinders 6 to 10).
If it turns out to be P0174 (lean, driver side only): monsta has it right, it's almost always unmetered air. Because only one bank is lean, look on that side. The fuel filter and the MAF feed both banks, so they'd normally set lean codes on both sides (P0171 and P0174 together). On these trucks, check: - An exhaust leak ahead of the O2 sensor. The older V10s are known for breaking exhaust manifold studs, and air pulled in at the leak makes the sensor read lean. Listen at the driver side manifold on a cold start for a tick that fades as it warms up. - The intake gasket and vacuum lines on that bank. A smoke test finds intake leaks faster than spraying around, and it will also show a crack at the PCV elbow monsta mentioned if one is hiding on the underside.
If it really is P0175 (rich): the usual causes are a leaking or stuck injector on that bank or a failing bank 2 upstream O2 sensor.
For the highway miss, have the codes read again. A cylinder-specific misfire code (P0306 through P0310 for the driver side) tells you exactly which hole to look at. With new coils already in, that points you at the plug or the boot on that cylinder.
Dana
https://partslogic.com |
