Questions to help troubleshooting
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 823
thallanor
• Leduc, XX, Canada
• Registered on 8/20/2009
Posted:8/20/2009 20:01
I previously owned a 2004 Ford Excursion Limited but within one year, foolishly traded it in on another vehicle. I recently purchased a 2005 Ford Excursion Eddie Bauer with 335,000 km (208,000 miles) on it, but I have some questions.
The first one is, can someone provide me photographs of the rear barn doors and hatch, focusing on the seals? I know that some of the seals are missing and I purchased a couple, but I suspect a couple are still missing due to the amount of dust and dirt that rests on top of the barn doors. The one I am suspecting is missing the most is one that runs vertical on the inside of the passenger side door. I have the L-shaped one on the driver side door that runs across and down, but on the passenger side, I just have the one that runs across. The dealership ordered a vertical seal for me, but it did not fit - it had Christmas tree clips but there are no holes on my door for them. The dealership thought that it might be a case that the doors are from an older Excursion because Ford changed the seals. I do not know. (The vehicle had been vandalized according to Carfax and they also hit a deer. Most of the missing seals and lackluster body fit is due to one or both repair jobs. I've found glass under the carpet in the back, so I suspect the vandalism was mainly the windows being smashed out.) Also, is that supposed to be a tight seal at the bottom of the front and rear doors? It gets caked with dirt and mud in there, and I can actually get my finger between the body of the vehicle and the door, without touching the seal - and it's like this on all four front doors. It just seems pointless, so I'm suspecting they put the wrong seals in or something.
This of course brings me to the next thing. Door fit and finish. Like I said, whoever did the bodywork obviously did it at quitting time on Fridays because the barn doors are not lined up properly. The drivers side one has had the paint rubbed through to the fiberglass. The front drivers door, when opens, has actually rubbed through the window seal on the outside, scraping it out. (Paint is also missing on the door.) Is it difficult to realign these? Can I just loosen bolts, try to line things up, and then tighten? (I just realized that it will be even more fun, since I won't actually be able to tighten them when they're in the right position.)
Before I forget, regarding the seals, if someone has a picture of the ones at the front of the hood, I would appreciate those too. I know that one is also missing, leaving the engine covered in bug remains.
I ended up pulling the knuckles and doing the front ball joints, upper and lower, so it would pass inspection. That was quite the experience - serves me right trying to save some money! But they're good now. I did find rusty sludge in the axle tubes though - not a lot, but a little, and the axles themselves were crusted, but I sanded them down and oiled them, and cleaned out the tube. Should I be concerned about some of that sludge in there?
The backup system keeps turning off when I put it in reverse. I remember my old Excursion doing this, but it was under factory warranty. The warranty on this does not cover that. How do I go about accessing those sensors? Can I pop the plastic off the top of the rear bumper? And where is the control unit located, so I can check it out?
Does anyone know if it is possible to pick up just one of the plastic pieces that covers the "arms" on the factory running board? One is cracked and sort of hanging. No other damage though.
When idling, I can hear a metallic rattly sound, almost as if - pardon this horrible example - you had a washer on a bolt and just set it on something vibrating. (Come to think of it, that example could be scary, if it's something similar to that.) It might be some random thing, but I thought I would mention it in case someone goes, "Oh yeah, that's so-and-so part, it does that," or something else well-known.
Okay, I'm getting there... not too much left, bear with me.
I like to let the vehicle warm up for two minutes - it is the 6.0 L turbo diesel and I know that with new engines, etc. etc. but I remember growing up to always warm them up, and I've just stuck with it. Anyway, if I do have to go relatively quickly and do not give it as much time to warm up, I've noticed two issues:
The transmission seems really reluctant to shift unless it really warms up. If I do not let off the pedal for a half-second, I'm sure I could redline the engine and it still wouldn't shift. I do not remember this with my old Excursion. After the transmission warms up, it shifts great, smooth as glass. Is there something that might need replacing? Any service that I should look at doing?
The next thing is again, with the engine not warmed up as much, at highway speed (nearing 60 mph and faster) the vehicle begins to surge, so rapidly it's almost a shudder. If I let off the pedal, then it goes away, but if I try to speed up again, it does it again. After the engine warms up - just a minute or so at these speeds - this goes away and again, smooth as glass.
It's not a real issue to me, but it might be indicative of something else, but I need to crank the engine about one, maybe two seconds, before it starts. Today, it took about three seconds. Again, not a big deal to me, though it is a bit of a concern since it is warm out, and I'm worried about what it might be like in the winter.
So really, that's about it. It's a bit of a list, but I think that it is stuff that I can fix. I do have an extended warranty from an aftermarket company on powertrain, seals (engine, transmission, etc. - not doors - d'oh!), and electronics. I figured it was worth it given the mileage on the vehicle.
The vehicle only cost $14,500 USD and the extended warranty for two years was $1,500 USD, so all in all, not a horrible deal. And I do love the vehicle. The next thing I need to do is replace the fuel filters - I've got them here in the box, just need to get a 35 mm wrench and/or socket. I also need to get an oil change done, as the dealership said they didn't do one, and the sticker on the window had the recommended mileage for the next one to be 10,000 miles -ago-. So it's a priority for me.
Anyway, if anyone has any suggestions, or can offer those photographs, I would appreciate it. I might go take photographs myself and show you the seal situation, so you can see what I'm talking about.
Thanks tons!
Posted:8/21/2009 20:46
First and foremost, WELCOME to the "X-Files" !!!
I'll chime in on a few things you addressed, and hopefully some others can fill in the blanks.
If you had another X, then you should know that a fair amount of dust and/or road grime collects atop the barn doors. That's not a weatherproof area.
The bottom interior-side faces of the doors ... below the interior plastic trim panels ... are other areas which are not weatherproof. The door weather seal is attached to the body, but I believe there are rubber lips at the bottom edge of each side door.
I have used several methods to hold doors in place while adjusting and/or fabricating hinge shims. One method is to suspend the door using an engine hoist ... another is to use a floor jack and a block of wood from below ... and don't rule out a stack of wood blocks and some wedges. Ya' gotta' be mechanically creative.
Don't do that. Crawl underneath and study the interior of the rear bumper. Popping the top plastic gains you no access, but you can get to them from below and behind the bumper. The sensor wires can be disconnected and each sensor can be removed. I don't know what you expect to do, but other than replacing them, there's not anything else you can do with them.
I believe that is another electronic gizmo operated via the GEM ... Generic/General Electronic Module ... located near the fuse box under the dashboard & left of the steering column.
Absolutely! Go see your local Ford dealer. You must have the optional chrome running boards and not the standard plastic boards with the integrated lights.
That can be a simple nuisance item, but it could also be something important. Track it down, identify it, then fix it before it drives ya' batty. I had a washer "jingle" on an old F350 that drove me bonkers until I hunkered down and sought it out.
With the old Excursion, you knew its service history. Since you don't know this one's, get the transmission filter and fluid changed ... not flushed, but changed. While you're at it, get all the fluids and filters changed.
Good luck & happy excursions!
edited 8/21/2009 20:58
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:9/1/2009 11:26
With the door weatherstripping--you can go to Home depot and buy narrow diameter plastic tubing. I don't remember the diameter. Using soap, you can thread this through the weep holes in the weatherstripping all the way around to restore it's thickness. I think I used the soft pliable tubing but you can search it on here and track down what most people use. On my 01, I had to use felt pads on the door to get the lower rubber bumpers make contact--place the pads on the door frame where the bumper will hit. I also lubricate my weatherstripping with the silicone tire shine. You'll be amazed how much quiter things will be...just don't get carried away with the silicone and get it messy--just a light coat is all that is needed
The tough part with the X of chasing rattles is half the time it's not coming from where you think it is--there is so much sound reflection inside. Check your glove compartment door--I had mine start rattling at idle one time. A little piece of self adhesive weather stripping can fix that.
I agree with Landyot-change the transmisson fluid and filters-I wouldn't probably flush it either with 200K on it. You could make it worse. My transmissiom went out at about 78K miles and it did something similar but much more subtle than you describe. If it's not been overhauled with that many miles, it's time.
I'm gonna guess you have a V10--if you do--Ford reccomends you have both timing chains changed at 200K miles--that could cause some idle/acceleration issues--plus it's a good thing to do to protect your engine. Also, you might need a new Idle Air Control valve--there's a little diaphragm that can get stuck-it'll make it have the starting problem. It's possible that it could be influencing your surges on the highway but I don't know for sure. Since you need to replace it anyway, doesn't hurt to try and see if that subsides as well.
My bad, I see you have the 6.0 l turbo diesel. I'm assuming the have an IAC valve so something to check.. Change your fuel filters as well. My bad again--you have that on your list as well.
Coil packs are another thing to check. I've never done it and the little buggers are expensive so you might ask the dealer on that one.
Another thought on the rattle, seems like somebody mentioned a shield over the catalytic convertor that rattled on them but don't hold me to that one.
If it's a diesel, there were some issues on some years with a faulty cam sensor that could make the engine cut off but I think that was only the 7.3 Powerstroke. The first year of the 6.0 turbodiesel was a nightmare--a lot of engines got shipped back to the factory in crates. I don't know about the 05's.
I'm not sure on the backup sensors, the only other thing I can think of would be the reverse switch that engages it when you shift into reverse. You can hunt down online service manuals to help you look.
Anyway, maybe there is something helpful in there. Good luck and welcome!
Heck since you have the warranty, I'd be tempted to take it to the dealer foa a full diagsnotic. Sometimes money is cheaper than stomach lining and heart muscle.
edited 9/1/2009 11:37
