V10 Fuel pressure problem
Thread Statistics:     Users to Post: 6   |   Total Posts: 9   |   Total Views: 18933
nhoj
• Hanover, PA, USA
• Registered on 1/9/2006
• 37 posts
Posted:11/27/2009 07:01
This engine was running great until three weeks ago. After being parked for about a week, I got in to start it and all it did was turn the engine over. No fire at all. After checking all the obvious, fuel filter (replaced), relays and fuses, inertia switch, then finally fuel pressure at the rail.
The rail pressure was only reading 18psi. I assumed fuel pump. Replaced fuel pump. Only ten pounds psi. Assumed defective (new) pump. They sent me another pump (OEM Motorcraft). Replaced again. Disconnected fuel supply and return at filter location, blew out lines (clear, no obstructions), same result (10psi).
I'm running out of ideas. Any thoughts out there?
01' Excursion V10 4X4
David Rush
• Greenville, SC, USA
• Registered on 4/11/2004
• 233 posts
Posted:12/12/2009 01:24
I'm by no means a mechanic but could there be trash in the tank preventing fuel from getting to the pump?
Posted:12/13/2009 19:30
Fuel pressure regulator? It works like a pressure relief valve. If it's not holding back an appropriate amount of pressure, then your pump is just running fuel through the lines, through the fuel rail, and back to the tank.
HBJJAM
• Minneapolis, MN, USA
• Registered on 6/23/2005
• 93 posts
Posted:8/3/2010 20:05
Seeing i am having same issue here, is there a way to 'test' te regulator?
Posted:8/4/2010 14:27
Test the regulator? Its job is to prevent excessive pressure in the fuel rail, but they can also leak, which prevents sufficient pressure from building.
I have never looked for it on my X, but I have worked on other engines where one can find a Shraeder (sp?) valve somewhere along the fuel rail. That's the location where one connects a pressure gauge, then turns the ignition on to see how much pressure the fuel pump can deliver. If the pressure does not reach the specified value, the pressure relief valve might have a small piece of crud keeping it from seating (closing) properly. The pressure relief valve should be located downstream from there ... could also be located at the opposite end of the fuel rail.
I've rebuilt a couple regulators (very simple devices ... spring, plunger, seals), and the material costs were always less than $10.
HBJJAM
• 93 posts
Posted:8/4/2010 16:14
Thank you for the input
Update is as follows.
was able to start the truck last night, but only drove 2 blocks before it sputtered to an end.
Let it sit overnight and nothing at all in the morning, no fire!
Brought home this afternoon, uncapped shrader valve and have nothing out of it!
I have pressed the fuel shutoff impact reset button several times. First time I thought I had it since it 'felt' like it pushed in
No my next test is to disconnect the fuel rail-line somewhere, thinking fuel filter and then do a 'quick' key test to see if any fuel pumps.
This gas tank looks like a major job, especially doing it in the street in front of the house. Since I have a steep driveway and am unable to pull it up there
Posted:8/4/2010 17:10
Did you have the ignition switch turned on (not cranking ... just turned to the "run" position) while you depressed the pin in the center of the Shraeder valve? If so, gasoline should come out until you released that pin. If no gas came out, then fuel pump is next thought ... assuming you've replaced the fuel filter already.
summerscheifer
• Carson, CA, USA
• Registered on 11/26/2010
• 50 posts
Posted:5/4/2012 03:12
The rail pressure was only reading 18psi. I assumed fuel pumps. Replaced fuel pump. Only ten pounds psi. Assumed defective (new) pump. They sent me another pump (OEM Motorcraft). Replaced again. Disconnected fuel supply and return at filter location, blew out lines (clear, no obstructions), same result (10psi).
I\\'m running out of ideas. Any thoughts out there?
coincidence that i am having the same issue. im planning to buy a new fuel pump either.
dnevins
• Subscriber since 12/29/2009
• San Diego, CA, USA
• Registered on 12/28/2009
• 340 posts
Posted:10/22/2026 22:14
nhoj, a third pump is not likely to help. Two new pumps both making the same low 10 psi points at something they all share: the voltage reaching the pump, the pickup and lines, or the regulator letting fuel straight back to the tank.
Three checks:
1. Voltage at the pump while it runs. Measure across the pump's own feed and ground wires at the tank connector (not feed to a random chassis ground) with the pump running. If it is well below battery voltage, the wiring, the relay contacts, the inertia switch or a bad ground is starving the pump and it will not make pressure.
2. Regulator, which LANDYOT already pointed at. It sits on the fuel rail with a vacuum hose on top. Pull that hose first: fuel in it means the diaphragm is gone. Then with a gauge on the Schrader valve, disconnect the return line at the regulator, cap the regulator's return fitting, and run the pump for a few seconds. If the pressure jumps way up, the pump is fine and the regulator is bleeding off. If it stays low, the problem is upstream of the rail.
3. If the voltage is good and the pressure is low even with the return blocked, look at the pickup and the sender assembly in the tank: a split hose or seal there lets the pump circulate fuel back into the tank.
HBJJAM, yours is a different case: nothing at all at the Schrader. Listen at the tank with the key turned to run. If the pump does not run for about two seconds, start with check 1, since that is a power, relay or inertia switch problem, not pressure.
Dana
https://partslogic.com
