Rear vent window help
Thread Statistics:     Users to Post: 6   |   Total Posts: 6   |   Total Views: 5072
buddy357
• Virginia Beach, VA, USA
• Registered on 6/16/2010
Posted:6/16/2010 20:22
I have a 03 Eddie Bauer Ex that I recently bought. I pulled the overhead console to repair the computer. It took a week or so to put it all back together.
Before I pulled the console both rear vent windows worked. Now that its all back together the passsenger side rear vent window doesnt work now. I am thinking I must have damaged the connector or the swith while it sat on my dinner table somehow. Or maybe I dont have it connected right. I have pulled it twice to reseat connectors to no avail. Based on it working before, I do not believe the motor is the problem.
Anyone have any recommendations on ways to test the switch/connector or even the motor? Or a wiring diagram that I can use to try to figure it out?Any help would be appreciated. Thanks.
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:6/16/2010 21:22
Just a quick idea to try is to make sure that one of the rear windows are not stuck close. If I leave mine closed up for any length of time, the glass will stick to the rubber. This happens more often when it's been raining.
Yahoo IM - kingsuv00
davecarpe
• Newton, NJ, USA
• Registered on 9/2/2007
• 29 posts
Posted:6/17/2010 05:05
I would agree with Bill. My rear vent windows stick all the time. Try pressing close then open if that doesn't work, a quick smak near the moter with the flat of your hand often frees it,
I would try that before you open the console again.
DReaux
• H-Town, TX, USA
• Registered on 7/14/2009
• 18 posts
Posted:6/17/2010 17:37
With the heat here in Houston, I simply open them every time I get in the rig... I've had them stick before, depends on the weather most of the time...
Basically, use it or lose it...
DReaux
Founder & President of
The H.L.M.F. Syndicate
princecasanova
• Los Angeles, CA, USA
• Registered on 10/14/2010
• 7 posts
Posted:1/12/2011 20:07
i used to have that same window problem. then i asked Auto Repair Questions on a source for good mechanic. hope you like it too.
Rancheroheaven
• San Jacinto, CA, USA
• Registered on 12/28/2010
Posted:1/25/2011 21:13
Un-plug wires from motor, hook multi-meter to wires, have friend push switch and see if you have power. No power? use multi meter to test at back side of switch, no power? test infront of switch. You can check switch using small wire clips and 12v cordless battery while out of the vehicle as well. Power at motor? motor bad
