Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ C/4 Fluid Leaking
C/4 Fluid Leaking
2 posts 2 contributors 1,742 views
19
19jap43OP
  • Member since Feb 2010
  • Jonesboro, GA, USA
Jul 4, 2010 at 9:12 PM
I need to change the shifter shaft seal. Can this be
done without removing the pan and internal workings?
Thanks for your expert opinions/instructions.
HO
hotrod628
  • Member since Jul 2010
  • Pecos, NM, USA
Jul 24, 2010 at 4:08 PM
Not 100% sure as you didn't list what you are working on but as far as I know I have never seen a automatic transmission shifter shaft seal being replaced without dropping the pan. And as long as you drop the pan consider changing filter if so equipped.
