Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ 1995 marquis trans problem..
4 posts 3 contributors 1,802 views
BB
BBRIDER15OP
  • Member since Sep 2010
  • Chicago, IL, USA
Sep 7, 2010 at 1:13 PM
I got a 95 marquis ls with 104,000 miles. Some times when Im driving with foot slightly on the pedal the trans will just slip into neutral.. This happens every now and then. Car shifts fine other wise I can floor it and go from 0-90 with no issues. Took it to autozone for a code scan and only got p1151 o2 sensor code and that was it but im sure thats not causing it. Also the gear shift indecator needle doesnt line up right, reverse is in between park and reverse,
neutral is in between reverse and neutral, and drive is almost on neutral. Any help on this problem?
JD
Sep 7, 2010 at 5:32 PM
Sounds like a misalignment of the indicator and the shift detent. If the shifter is locking into place when you put it in Drive, but the indicator is off, you can get used to it. If it isn't locking properly, look for a mechanic.
BB
BBRIDER15OP
  • Chicago, IL, USA
Sep 7, 2010 at 6:57 PM
Thanks for your response. could that be the reason it shifts into neutral while driving too?
ST
stamey68
Sep 26, 2010 at 2:36 PM
i have an 02 that done same thing,go into neutral before overdrive,it was bad clutches..something you can try-drain all fluid including torque converter..put in shutter stop and 1 quart lucas then finish with tranny fluid..maybe this will help.
