Home/ Forums/ SuperMotors Topics/ SuperMotors Support & Suggestions/ \\\\\\'88 Town Car
\\\\\\'88 Town Car
2 posts 2 contributors 2,927 views
QU
quarterhorseOP
Jan 30, 2011 at 4:38 PM
Have a situation with flickering headlights. Have put in new multifunction switch and also headlight switch. Problem still there. After roughly 20 minutes of driving with lights on....they start flickering off and on.
Am running Sylvania XtraVision Halogens. Could this be the problem....too much current draw for the switch? The headlight switch gets pretty doggone warm after a while.
Is there anyway to resolve this, short of taking out the halogens?
DN
dnevins
Oct 30, 2026 at 10:44 AM
What you're describing, lights that run fine for a while and then start cycling on and off as things warm up, is the classic sign of the circuit breaker built into the headlight switch tripping and resetting. On 1987-88 Thunderbird Turbo Coupes, which are Fords of the same era, the regulars on the T-Bird forum blame this kind of flashing on that breaker. Lincoln Land has also pointed to the breaker inside the headlamp switch, and to a bad connection at the switch, on older Town Cars.
Since you've already put in a new switch and it still gets hot, look hard at the connector that plugs into it. One owner of an 84 Thunderbird replaced the headlight switch, the alternator and the battery and still had the flicker. The plug at the turn signal and dimmer switch had overheated and gone brittle, and new terminals on that plug cured it. A new switch doesn't come with a new plug, so check the plugs on both switches you replaced. A loose or cooked terminal makes heat right at the switch, and that heat trips the breaker.
On the bulbs: Sylvania sells the XtraVision sealed beams as DOT-compliant direct replacements for the factory lamps, so I wouldn't blame them first. You don't have to give them up either way. A headlight relay harness lets the switch power only the relay coils, while the relays feed the lamps straight from the battery. That takes nearly all the heat off the switch and its connector, whatever bulbs you run.
Dana
