Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ Weird Engine Noise
Weird Engine Noise
3 posts 3 contributors 2,289 views
LA
lateefOP
  • Member since May 2011
  • Waukegan, IL, USA
Feb 28, 2012 at 4:19 PM
when i start my car i hear grinding noise i thought it was low on oil but then i seen small metal shaving all over the place.....This is a 2000 crown victoria police interceptor
WI
wizzard1222
  • Member since Jan 2011
  • 139 posts
  • Ballwin, MO, USA
Feb 28, 2012 at 5:03 PM
Well for me...I need a lot more data input....
But if you 'see a lot of meta shaving'...I would not try to start the engine any more...!
You need to do a lot of "offline" research around the engine and areas that you see
the shavings....possibly getting an experienced Friend to come-N-help you.
It's hard for anyone to help w/the limited info provided....
w/o audio, video clips...being in your shoes.
You may have to finance an experience mechanic to come & do a "complete"
LOOK IN & Inspection.....but be careful of their ego/experience level for their
asking $Price to achieve your assignment.
As a home inspector would do....Have them provide detailed notes of their observation....
My 2 cents....
JD
Feb 29, 2012 at 6:37 AM
"then i seen small metal shaving all over the place"
Exterior of the engine? In the Oil when you checked the level? This does mean different things.
Metal shavings on exterior parts means something is rubbing. A loose bracket, worn bearings in a part, or just parts interfering with each other will cause small metal shavings all over the place. (A fan hitting an aluminum covering, for example.) Do a thorough visual inspection before you start it again.
If its in the oil, Hasta La Vista Baby! Its rebuild time.
edited Feb 29, 2012 at 6:39 AM
