Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ 300 to 302
300 to 302
6 posts 3 contributors 1,519 views
TJ
Tommy JohannsenOP
  • Member since May 2003
  • Ft.Worth, TX, USA
May 27, 2003 at 10:55 AM
antbody know if a 4-speed tranny from a 1986 bronco will fit the 302 the trans came off a 300 straight 6 from the same truck any direction would be appreciated as far as clutch, any potential problems the motor is almost ready I cant wait to yank out the old 300 and put in the built beast!
NL
Nick Loesch
May 28, 2003 at 9:30 PM
As far as i know there different. You might want to try contacting your local repair shops.
LW
Linny Wingard
  • Member since Mar 2003
  • 28 posts
  • Charlotte, NC, USA
May 29, 2003 at 8:22 PM
The 300 and the 302 use the same bellhousing. The only major difference is that the 302 uses a counterweight on its flywheel and balancer. The 300 is internally balanced, and uses a flywheel with no counterweight. Get a 302 flywheel (28 oz. or 50 oz., depending on the year of the engine), some 302 motor mounts, and have fun!
NL
Nick Loesch
May 30, 2003 at 3:06 PM
My bad, sorry for the confusion, I always thought an I-6 would have a different bellhousing than a V-8 would.
LW
Linny Wingard
  • 28 posts
May 31, 2003 at 7:46 PM
The small 144-170-200 sixes had a different bell, but the 240-300 big six and the 250 small six used the 302 6-bolt pattern.
TJ
Tommy JohannsenOP
  • Ft.Worth, TX, USA
Jun 3, 2003 at 1:48 PM
thanks guys I got all the parts off of the old bronco to put on the new such as motor mounts I just wasnt sure about the tranny thanks for all your help
