Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ LCM question - re 2004 Crown Vic
3 posts 3 contributors 1,841 views
DB
dbcanOP
  • Member since Jun 2012
  • Kitchener, XX, Canada
Jun 8, 2012 at 5:15 PM
I have a 2004 Crown Vic -- with a Light Control Module problem. I have access to a used LCM -- that appears to be the same physical size, plug configuration, etc. However, its Part number is:
5W7T13C788AB
I was told it came out of a 2004 Crown Vic.
When I search that part on the Internet -- it seems to relate to the LCM of a 2005 Crown Vic.
Do you know if the two LCM units are interchangeable -- or not?
Could I do any damage in "trying" the replacement unit in the vehicle?
Thanks for any suggestions and advice you can provide
JD
Jun 8, 2012 at 5:57 PM
Don't forget that throughout a particular model year the manufacturer may do upgrades and revisions to any and all parts of a vehicle. Depending on the exact date your 2004 was made, it IS possible for it to have a part that was STANDARD on the 2005 models. I have a 1997 CVPI which has parts associated to the 1998 models. Weird, huh?
All I can suggest is to try the LCM and see if it works. If not, go to ebay and have fun!
HO
hondaclf
Jun 8, 2012 at 9:18 PM
Many if not all of the LCM's of that generation had the same/similar problems so getting another used one will just "fix" the problem for a time then it too may fail.
What is the problem you are having?
