Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ 04 crown vic wo`nt start
4 posts 4 contributors 1,464 views
GR
greyghostvicOP
  • Member since Jun 2012
  • council bluffs, IA, USA
Jun 23, 2012 at 6:17 AM
My good deal might not be a good deal. 04 p71 new fuel pump, crank sensor, new ignition switch and 3 different SMUs still not running. Not getting a check engine lightand fuel pumpdos not run. Not sure where next to turn.
JD
Jun 23, 2012 at 6:34 AM
Try the following link: http://www.cb7tuner.com/vbb/showthread.php?t=147239 for the Chilton manual. A shop manual would explain the steps you need to go through to find out what is wrong.
Did you try to get a scan from the OBD? I have seen people say they had no Engine Light come on, which turned out to be a burnt bulb. And any code you do get may not be what is wrong. I once had a code for a bad O2 sensor. After a Google search, it turned out to be a vacuum leak. Replacing vacuum hose, $1.20; if I would have replaced the sensor $115.
Also, try www.crownvic.net for additional help.
edited Jun 23, 2012 at 6:35 AM
JW
jwar1127
Jun 23, 2012 at 6:56 AM
Do you have a pats or a security system?
CE
ceptor1
  • 12 posts
  • Huntsville, AL, USA
Jun 23, 2012 at 11:02 AM
I have an '03 Ford factory manual with wiring schematic manual if that would be compatible I might could help?
