Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ 1999 P71 Won\\'t start
3 posts 3 contributors 2,770 views
HS
hsnoriderOP
  • Member since Jun 2012
  • Boise, ID, USA
Jun 30, 2012 at 12:07 PM
I have a 1999 Ford CVP P71 that died while driving down the road. The starter cranks like normal but the car wouldn\\'t start. On closer inspection all the fuses and relays both under the hood and the dash are good, But there are two brown wires in the ignition switch wire harness that do not have power in any key position but when I jumper them to a \\"live\\" wire the car starts and runs like normal except when I turn the key off the car keeps running until i pull out the jumper. Any Ideas would be great thanks.
WI
wizzard1222
  • Member since Jan 2011
  • 139 posts
  • Ballwin, MO, USA
Jun 30, 2012 at 1:03 PM
Sounds like you are @the point of the issue....
Are the two brown wires part of the ignition switch...?
Is there any indication where these two brown wired trace to/from that is replaceable...?
Have you checked the OBD2 codes...?
JD
Jun 30, 2012 at 2:22 PM
If you do not have a Chilton or Haynes manual to look at the wiring diagram, try this link: http://www.cb7tuner.com/vbb/showthread.php?t=147239
I haven't looked at the 1999 version, but I suspect that you have a bad ignition switch. You said you put a hot wire to the 2 brown wires in the switch. That is what leads me to believe the switch itself is bad. I'm not talking about the ignition lock that your key fits in, but the actual contact switch in the column. Hope this helps.
