Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ No throttle cable on 2006 CVPI?
3 posts 2 contributors 1,364 views
MY
MyFordAgainstYourHondaOP
  • Member since Sep 2012
  • 26 posts
  • South Florida, FL, USA
Sep 16, 2012 at 2:33 PM
I noticed while i drive my car accelerates normally until it hits 1,000 RPM at 40mph, it seems like the car goes into a low gear, thats the only way i can explain it. Someone told me that theres a digital throttle sensor for the 2006 model, where is it located and whats the exact part called?
HO
hondaclf
Sep 16, 2012 at 3:06 PM
You have "drive by wire", everything from the gas pedal to the throttle body is electronic.
If there was a fault in the system, you should get a fault code(CEL).
You can try resetting the sensor by going through a series of steps:
- turn the ignition key to the -ON- position, but DO NOT START the vehicle.
- slowly depress the gas pedal to the floor.
- quickly release the gas pedal.
- turn the ignition key to the -OFF- position.
- Repeat the above 4 steps, 2(two) more times.
edited Sep 16, 2012 at 3:07 PM
MY
  • 26 posts
Sep 16, 2012 at 7:17 PM
I just did the test on my car, i didnt drive it though. Was i supposed to have it hooked up to a computer while i did the test?
