Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ 99 Crown Vic 4.6 Engine Rattle
4 posts 3 contributors 1,625 views
FI
firstfordeverOP
  • Member since Oct 2012
  • Monee, IL, USA
Oct 19, 2012 at 11:12 AM
Hey I have a rattle that I can not figure out it sounds like its coming from the front passenger valve cover here is a link to the engine running and making the noise...it is not constant ....
http://www.youtube.com/watch?v=jEF3U5WF4HM
JD
Oct 19, 2012 at 2:45 PM
Have you tried pin pointing it with a mechanic's stethoscope? Or you can use a length of fuel line to your ear and listen with the other end close to the noise. You can spot exactly where the noise is coming from.
Also, when was the last time you did a tune-up. If its been over 50K miles, replace plus, filters, and pcv valve.
FI
firstfordeverOP
  • Monee, IL, USA
Oct 19, 2012 at 2:56 PM
I just replaced the plugs coil packs fuel and air filter the idler and tensioner pulley it has 95000 on it car runs perfect but the noise is there here and there, I just changed the oil and used Valvoline synthetic and a bottle of Lucas oil treatment might of helped a lil bit
RS
rss459
Jan 2, 2013 at 12:44 PM
Wow just ran across this post nosing around and by golly the youtube video that is pointed to is one I made on my car and is in my account. I can only hope it is being used as an example which is fine. Just curious however.
Oh FYI solved this: AC Clutch
