Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ Problem with 93 grand marquis
2 posts 2 contributors 1,261 views
SH
Shorty74OP
Nov 11, 2012 at 8:37 PM
My 93 grand marquis keeps blowing the 20a ignition coil fuse under the hood. It will drive for a second then blow. Any suggestions on where to start.
JD
Nov 12, 2012 at 6:56 AM
If you have the Haynes or Chilton manual, trace down the wiring diagram from the fue forward. To blow a 20amp fuse means you have a short, but where is the problem. Finding a short takes quite a while to trace each wire in the circuit to check if it is frayed. Also, it could be an internal short in the coils.And it will be time consuming.
The fuse is between the power supply and where it is shorting out. Start unwrapping wiring and check them carefully. Eventually you will find the problem.
