Home/ Forums/ Car and Truck Make and Model Specific/ Other Ford Trucks/ 2150 Carb on 1984 ford 250
Other Ford Trucks
2 posts 2 contributors 2,381 views
RB
rb33OP
  • Member since Dec 2012
  • Cove, OR, USA
Dec 3, 2012 at 4:37 PM
I-m working on a 84 , 250 W/ automatic that has been run very little for the past several years. I took the carb off and had it rebuilt and installed a manual choke. It starts right up but does not want to idle. Other than the two adjustment screws on the front of the carb which are air adjustments I believe. Where is the idle adjustment screw.
PN
pnp522
  • Member since Sep 2012
  • Lompoc, CA, USA
Dec 3, 2012 at 6:11 PM
check for vacuum leaks. There may be one around the gaskets. Also the plastic and rubber vacuum lines get brittle and crack.
