Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ Hard to start start
Hard to start start
5 posts 4 contributors 1,384 views
LD
ldj1002OP
  • Member since May 2012
  • 8 posts
  • Marlin, TX, USA
Jan 22, 2013 at 12:56 PM
2002 crown Vic 65,000 miles. It isn\\'t real hard to start. When you turn the key it spins over several times failing to start, release key and try again and it starts right up. It started doing this maybe 6 months ago but would do it only only on in a while. Now it does it nearly every time. However it always starts on the 2nd try and it runs perfect. I am afraid it will get to where it won\\'t start. Any ideas??
L.D.
CU
curemode2002
Jan 22, 2013 at 1:01 PM
Sounds to me like a fuel issue as opposed to a spark or starter issue. Have you checked the fuel pressure with the key turned on but the motor not running? Also the obvious has the fuel filter been changed?
JD
Jan 22, 2013 at 6:33 PM
Change the fuel filter, and possibly a spark plug change.
LD
ldj1002OP
  • 8 posts
  • Marlin, TX, USA
Jan 23, 2013 at 7:27 AM
Thanks for the info. I will change filter, it's never been changed.
CE
ceptor1
  • Member since Jun 2012
  • 12 posts
  • Huntsville, AL, USA
Jan 23, 2013 at 2:58 PM
I am still subscribed to this post even though I sold my '03 interceptor, I have a factory '03 service manual also the wiring manual that goes with it, I can help with the info but I would need some specific direction where to look in the manual. That is if an '03 manual is compatible with an '02.
