Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ 06 CVPI - spotlight works only in certain direction and done…
06 CVPI - spotlight works only in certain direction and done light works on and off
3 posts 3 contributors 1,462 views
FA
Falcon83OP
  • Member since May 2013
  • Saint Louis, MO, USA
May 3, 2013 at 9:06 PM
Close to buying an 06 PI. Mechanic checked in out and gave two thumbs up on the engine, tranny and suspension. The only thing he noticed, was the dome light works on and off. Sometimes it will go on and then sometimes it will flash quickly but not come on. You mess with it and sometimes it will work and then won't...
The other weird thing is the spotlight. If you flip it on while in the down position it won't turn on, but if you twist up and to the left it will work. It will then turn off when you move it to the right..
Any thoughts or experience with this? Thanks!
HO
hondaclf
May 4, 2013 at 6:15 AM
Does the dome light do the same thing when you turn it on with the headlight switch? Have you tried a new bulb?
The spotlight probably has a chaffed wire in there, just unplug it and don't use it.
JD
May 4, 2013 at 6:25 AM
In both cases, the first thing I would do is clean the switch. Then start checking wiring.
The dome light probably has a dirty switch. A couple of shots of non-lubricating contact cleaner should clean it out.
The spotlight may have a chaffed wire. Rewiring it shouldn't be a big problem.
Go to the forum www.crownvic.net to check out some of the items written about including these.
