Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ When should you transform your car\\\\\\'s brake pads?
2 posts 2 contributors 2,883 views
OC
octeobd2OP
  • Member since Nov 2013
  • new york, CO, USA
Nov 20, 2013 at 1:40 AM
The lifespan of a set of brake pads is dependent on a diverse reasons-C material, form, composition, driving style, maintenance, heat, stress, fraction, and so on. Mechanics and producers reveal that pads can last from a mere 100 miles to an astounding 100,000 miles. Offered such far-ranging numbers, how can you know when do your brake pads need to be changed?
Of course, the ideal time to take care of brake pad issues or brake troubles is just before they occur. By applying some car diagnostic tool, that do not need much more mechanical experience, a single can simply get out irrespective of whether the brake pads are worn.
A obd2 scanner will perfectly solve the issue. The tool will produce you with one or much more codes, pointing problems together with your car method. And you can discover if the brake pads are alright soon after looking up what the codes imply.
JD
Nov 20, 2013 at 9:04 AM
Taking a look at the pads in the calibers is an easier way to tell if they need changing.
