Home/ Forums/ SuperMotors Community Discussion/ Engine and Drivetrain/ oil in the plug well
3 posts 3 contributors 1,924 views
TC
tclayOP
  • Member since Dec 2013
  • earlville, IA, USA
Dec 1, 2013 at 6:42 AM
I have a 1999 crown vic police interceptor I was changing the plugs and found oil in the plug well next to the firewall( drivers side) I was told a cracked head . she runs good any ideas on how or why the oil is in there?
JD
Dec 1, 2013 at 7:46 AM
Check for leaks in hoses. Possibly oil from the PVC valve leaked there, if it is on that side. Or a loose valve cover, or bad gasket.
Check those out before swapping heads.
BE
Bertini
  • Member since Jan 2014
  • linyi, AR, St. Lucia
Jan 2, 2014 at 9:30 PM
There is an O-ring that seals the spark plug well and keeps oil from leaking into it. As with any valve cover gasket, it will start to leak over time. Sometimes tightening the valve cover bolts will stop the leakage, but more often than not the valve cover gasket, and well seals, will need to be replaced.
CAR OBD2 SHOP
