Home/ Forums/ Car and Truck Make and Model Specific/ Crown Victoria, Marauder, Marquis/ Brake light on dash
Brake light on dash
3 posts 3 contributors 1,161 views
LD
ldj1002OP
  • Member since May 2012
  • 8 posts
  • Marlin, TX, USA
Dec 1, 2013 at 8:57 AM
2002 Crown Victoria
Brake light in instrument panel comes on at times. If it is on or off it makes no difference how the brakes work. As far as I can tell they work just fine. This dash isn't the electronic dash if it makes any difference.
HO
hondaclf
Dec 1, 2013 at 2:11 PM
It could be that the fluid is low
DB
dbmcd
Dec 6, 2013 at 4:41 PM
The brake light in the upper right hand corner of the dash comes on when the emergency brake is applied. You are possibly driving around with it partially clicked on. Check to see that it is off completely, if so, check to see if the micro-switch is adjusted correctly.
