Home/ Forums/ Frequently Asked Questions/ Registry Entry Questions/ Knowledge of pipes and fittings series
1 posts 1 contributors 6,833 views
PI
pipe201308OP
  • Member since Dec 2013
  • china, AL, USA
Dec 8, 2013 at 8:00 PM
One . Tube System Overview :When the water line must be used once the elbow flex , when to use the size of the top pipe reducers , bifurcation : So that you can transport liquid or fuel , you must make use of a variety of routes , in addition to directly Alloy Steel Pipe with metallic pipes , but additionally use all types of pipe furnishing use the links, use flanged tube joints along with fittings any time connected to the indication medium to achieve the open goal , but also with a variety of valves , to scale back the effects involving thermal enlargement or shrinkage frequent shake of the direction system , but also with expansion section . Additionally, in the pipeline , as well as with some other instruments connected to various joints ?p plug and so forth. We are used to the steaming system and other accessories other than a straight tube referred to as pipe fittings.
Two . Metallic components common sense: Metallic material is on our daily lives and also the most widely used business materials . It can be mainly divided into the metal , iron along with non-ferrous metals and also other categories , and one of the most trusted steel is the most common substance , the main component in material is metal , and the rest is unnaturally added alloying factors and various impurities. It is because with the different varieties of these alloying components added . Distinct quantity before the formation of your variety of metals such as plain carbon metallic , stainless steel, [b]Alloy Steel Pipe[/b], etc. , these extra elements , carbon dioxide plays an important role throughout C .
