Power inverter?
Thread Statistics:     Users to Post: 5   |   Total Posts: 7   |   Total Views: 617
Texas4x4
• Tyler, TX, USA
• Registered on 7/25/2003
• 289 posts
Posted:8/4/2003 14:36
Has anyone added a power inverter to their rig? If so, what size, where, how, etc...
TIA
Kevin Curry
[email protected]
http://www.texas4x4.com
Posted:8/4/2003 16:31
Kevin,
I just went to Target and picked up a single outlet power inverter. It works great for powering a 14" TV and X Box. Don't remember the size, but they make different sizes depending on how much juice you need. Cost was about $40 if I remember correctly...
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:8/4/2003 17:19
I have a little 350W jobber which connects via cig lighter... I was thinking more along the lines of 1000W or more to run tools and stuff off of - one which would be hard-wired into the cabin somewhere. Thanks for your response, though.
Kevin Curry
[email protected]
Posted:8/9/2003 15:13
Kevin,we went by Harbor Frieght and picked up a 800 watt unit with twin internal fans which is hard wired in.
We use it to power anything from a small 13" TV,DVD player,Laptop or anything in between
BILL
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:8/9/2003 16:03
Kevin,
Try this link for a cool solution. The invertor itself is a little week but you can switch it out for a bigger one!
http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=MV&Product_Code=110GAMER
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
edited 8/9/2003 16:07
Edward Newman
• Long Island, NY, USA
• Registered on 12/9/2003
• 18 posts
Posted:12/9/2003 11:15
I have a ProSine 1800 installed under the middle seat, drivers side. It will provide power for almost anything you can image but if you do not keep the truck running, it will drain the battery in miniutes if you put a heavy load on it. Also keep in mind that you will reduce the life of your alternator.
Texas4x4
• Tyler, TX, USA
• 289 posts
Posted:12/9/2003 13:09
I ended up buying a 1000W inverter from Costco and mounted in on the tranny hump in the front.
Kevin Curry
[email protected]
Power inverter?
