engine runs ruff after car wash
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 558
trauski
• indianapolis, IN, USA
• Registered on 3/10/2003
• 44 posts
Posted:8/14/2003 13:49
since i bought my 2000 v10 x a in the spring of 03 every time i go through the car wash it runs really ruff for about 10 minutes.it sputters and sounds likes its gurgeling.. is this normal or am i getting water some wear. i have not done the zoo dad modification. but i have thought about it except that this happens in a car wash and i still have extended warrenty left.
Pharmer
• Mackinaw City, MI, USA
• Registered on 12/19/2002
• 52 posts
Posted:8/14/2003 14:32
Wash it yourself, just kidding. Check the all the clamps on the air induction system. On mine the clamp nearest the throttle body came loose. Maybe some water is getting in when that big blower comes on at the end of the wash. I run mine through car washes in the dead of winter and have no problems.
I did a modified way zoodad that won't look so bad and avoid the sucking in of water. Once you remove the grill you will see the vertical support on the drivers side. The snorkel of the air cleaner is behind this in a closed space. Pull back the rubber hood seal and look down. You can use a lock set hole saw in a drill and drill a hole on the outside of this support below the level of the snorkel. Once the grill is installed you only see the hole through the side grill.
gearman
• los Angeles, CA, USA
• Registered on 1/22/2003
• 336 posts
Posted:8/14/2003 14:34
well, i think its safe to say you are getting water where it shouldnt go. finding it can be tough. make your dealer fix it. dont be surprised if it takes more than one visit.
Posted:8/14/2003 14:46
Your air filter is most likely getting wet. After your next car wash, pull out of the stall and open the airbox and pull out your filter to feel if it is wet or not. If you inspect all of the clamps and can't find something wrong, do like gearman says and bring it to your dealer.
