Brake Question
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 551
Wheels
• Visalia, CA, USA
• Registered on 1/20/2003
• 214 posts
Posted:9/30/2003 09:21
Does anyone know if the Excursion brakes are as easy to change as say those of a Chevy??? My neighbor (manager/mechanic) showed me how to change brake pads and rotors on his '93 Chevy Pickup, and after seeing how unbelievably easy it was, I am pretty sure I can do the ART brake kit myself (with his supervision) . I was just wondering if anyone knew of anything that a "shop" might have to do???
Thanks in advance.
Jason
Phil Eaton
• Lander, WY, USA
• Registered on 4/28/2003
• 42 posts
Posted:9/30/2003 10:49
Yes, the x should be similar to the Chevy. I changed all 4 discs, pads and bleed the system in about 4 hrs. without drama. It helps to have some hydralic jacks, jack stands and torque wrench. Its fairly gratifing and you also can verify on a personal level proper nut and bolt torque.
watchintv
• Saddle River, NJ, USA
• Registered on 5/6/2003
• 72 posts
Posted:9/30/2003 16:09
Don't forget the anti-squeak compound for the pads. I didn't put any on my ART's and I regret it. It's not a horrible squeak. Usually it's fine, only when I'm in traffic and the brakes heat up.
Posted:10/2/2003 21:09
Thanks in advance.
Jason
Brakes are easy! Just follow the install article:
http://www.fordexcursions.com/installs/install_1/index.php
Brake Question
