Anti-sway question
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 535
Daniel liguori
• san diego, CA, USA
• Registered on 11/29/2003
• 19 posts
Posted:12/21/2003 21:49
I was wondering if a lift will effect the performance or the aability to install rear anit-sway bars?
Posted:12/21/2003 23:40
Daniel,
The Hellwig rear anti-sway bar by default comes with adjustable linkages. I'm not sure what the magic number is in lift height that requires larger linkages with the Hellwig bar, but it's something that any welding shop can easily fabricate for you. If you are having the lift installed, most likely the 4x4 shop will be capable of doing this for you.
Daniel liguori
• 19 posts
Posted:12/21/2003 23:41
Thanks for the 411 Eric!!!
spartan
• Nashville, TN, USA
• Registered on 7/17/2003
• 87 posts
Posted:12/23/2003 09:05
The adjustable links will go cover you up to a four inch lift without a problem. Over that and you may want to have some custom made. Good luck.
Anti-sway question
