What's Covered Under Warranty?
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 420
Justin Hooper
• Oswego, IL, USA
• Registered on 4/4/2004
Posted:4/4/2004 19:15
I just bought an excursion. It's got less than a month left on the factory warranty. I have had no problem getting the first round of obvious problems fixed, but am curious if anyone knows if the following are covered...
Stitching coming loose on leather seat opened up a hole . THIS IS NOT A CUT in the leather. The stitching between the bucket and the side has come apart. I only noticed because I was applying leather treatment.
Clunk under the front – Front end suspension. It has to be a control arm, ball joint, or something. Also has a bearing noise I believe.
Anyone what I can expect to be covered?
What should I pay for an extended Ford warranty?
Thanks.
- Hoop
edited 4/4/2004 19:16
Posted:4/5/2004 07:22
The factory warranty should cover everything you listed above. The clunk under the front of the vehicle is most likely a loose body mount/bolt or sway bar bolt. Get those fixed before your warranty expires!
For pricing on different extended warranty configurations, you can go to this site http://www.fordesp.com/.
Justin Hooper
• Oswego, IL, USA
Posted:4/5/2004 13:11
Thanks chief! I have an appointment scheduled. I looked at the pricing on the FORDESP page and it looks like the dealers have the ability to "play" with that a bit, because I was quoted slightly less... but it's an awesome bench mark.
Thanks for the response... BTW nice truck!
