2000 Excursion Paint Peeling
Thread Statistics:     Users to Post: 5   |   Total Posts: 6   |   Total Views: 1840
sfd4
• Linden, NJ, USA
• Registered on 4/14/2004
• 31 posts
Posted:4/16/2004 19:55
I have paint peeling from the rear side door jams and from a small section of inside of door. It peeled right down to the primer. Any one else experience this?
2000 Excursion V10 Limited. White/Tan
2004 Fleetwood 34ft Travel Trailer
Posted:4/21/2004 11:15
The only paint peeling problems I've had are where rocks have chipped away the paint. My driver's side door has taken a beating just behind the window.
Biggone
• Panhandle, FL, USA
• Registered on 12/23/2003
Posted:5/10/2004 09:23
I have the exact same problem. It is also peeling from the top on the passenger side in the drip rail. I took to Ford...no luck. I took to a lawyer...no luck. I will repaint myself. Terrible for a 50K truck!
00 4X4 PSD Limited Excursion
00 Eddie Bauer Expedition
More VW's than we can count
03 Jayco Eagle 314
Jon R
• manchester, NH, USA
• Registered on 1/29/2003
• 17 posts
Posted:5/11/2004 11:35
just the clearcoat or the paint as well?
sfd4
• Linden, NJ, USA
• 31 posts
Posted:5/13/2004 16:04
It is peeling down to the primer! White paint and clear coat!
zestar
• Novi, MI, USA
• Registered on 7/8/2010
Posted:7/8/2010 05:27
Paint durability data associated with the Ford Excursion is
documented in the research publication:
MAKING IT RIGHT
Why your Car Payments are lasting longer than your
FACTORY PAINT JOB
There has also been an independent review done of this publication by
\\\\\\"ForeWord\\\\\\".
Automotive paint durability research publication documents vehicles released to dealer and consumer below automaker\\\\\\'s minimum paint thickness specifications.
Refer to link for details.
Link: http://www.forewordreviews.com/reviews/making-it-right-why-your-car-payments-are-lasting-longer-than-your-factory-paint-job-basic-guide/
