Ride / Handlign Sucks! Advice???
Thread Statistics:     Users to Post: 9   |   Total Posts: 16   |   Total Views: 2144
dzl_x_4x4
• Dallas, TX, USA
• Registered on 8/15/2003
• 7 posts
Posted:5/12/2004 15:01
Pastuki, I had the same problem and by coincidence sold the ranchos to Johnboy. Read my post of what effects tires, shocks and sway bar make.http://www.northtexaspowerstrokes.com/forums/viewtopic.php?t=485
Also, I am not sure what air pressure you run in your tires, I run 50-65psi, recommended on the sidewall of the tire (I don't care what ford recommends). That made a big difference on our 8K lbs X's. I just lifted and put on multiple shocks in front, everything is Procomp and I have the MX-6 adjustable shocks all the way around and it still rides 300% better than stock and even better than stock with the Rancho's 9000X's.
Go for good tires, shocks and a sway bar, you will not be disappointed.
Dzl_X_4x4
85MH325
• Eastern, IA, USA
• Registered on 3/20/2004
• 54 posts
Posted:5/12/2004 21:32
Hey, shock shoppers... check out Edelbrocks! They're amazing! I also run 55psi standard, 70psi in my "E" range R4S Firestones towing my 8500lb trailer. Tire pressure makes a HUGE difference in the handling too.
Roger
edited 5/12/2004 21:34
Posted:5/12/2004 22:05
Hi there dzl_x_4x4 !!!
Those shocks are BETTER than you told me...
unlike you though, I've increased my air pressure a bunch and dropped the shock settings down a bunch to get the best of both workds...
my ride is softer and my fuel mielage is up !!!
Thanks again and great meeting you !
Did you make the northtexaspowerstrokes.com Rally ????
Bet the weather was FUN !
Martin Gallardo
• LOS ANGELES, CA, USA
• Registered on 8/3/2003
• 12 posts
Posted:5/15/2004 00:31
where can I get the sway bar and the rancho shocks for my X?
Posted:5/16/2004 09:53
Summit Racing & J.C.Whitney seem to be the two most common sources for the Hellwig anti-sway bar. Rancho's? Do a search online. There's countless distributors for them.
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:5/20/2004 04:40
Check your local 4x4 shops!! Maybe they can get a decent price too!! But like the others have said online is probably the best!!
Good luck!!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
