2005 headlight upgrade
Thread Statistics:     Users to Post: 6   |   Total Posts: 11   |   Total Views: 2014
rab986
• Broken Arrow, OK, USA
• Registered on 11/7/2003
• 34 posts
Posted:11/14/2004 22:56
I was looking at a new superduty and was wondering if anybody had tried to install the new 2005 headlights in their pre '05 Excursion. From what I could tell they mount exactly the same as our lights do and physically look like there would be no problem putting them in....but before I drop that kind of jack I would like to know if anybody else has done it.
My UAV
2002 Ford Excursion Limited Ultra, Powerstroke Diesel, Garrett Max Power Ball Bearing Turbo Kit, K&N FIPK, Banks Power Elbow, Banks Monster Exhaust with 4" Downpipe, 8" Skyjacker Z-LInk Suspension, American Racing Teflon Mojave 18" Wheels, Nitto Mud Grappler 38x15.50x18, Banks Trans Command, Garmon Custom 4 position chip 150hp 36lbs of boost. Alpine DVD IDV900, JL audio 12w7, Boston mids and highs, JL 1000/1 and 450/4 amp, Warn 16.5Ti Winch, Warn Semi Hidden Winch kit, Con Fer Rack w/Highlift, shovel, axe and spare mounts, Hella 4000 serias lights, ProComp light bar, and I can't think of much more off the top of my head.....
J-Douglas
• San Antonio, TX, USA
• Registered on 3/18/2004
• 90 posts
Posted:11/15/2004 03:00
Going on what my dealer-friend has told me, the headlight assemblies are in the same position. I have been told that the only difference is that the grill goes farther down into the top of the bumper on the '05. So, if he is correct, then the '05 headlight will fit just fine into the pre '05 Excursion.
My opinion..... I think they would fit fine. I looked at my '04 and the headlight assembly screws into the fender frame and front..... DAMMIT I FORGOT THE NAME OF THAT PIECE!!!! It's the main cross-bracket that the radiator and everything else bolts onto.
So, I am GUESSING that Ford would not have replaced or re-worked all this inner componentry just for one year production run of the '05.
I wouldnt see much reason with going with the '05 headlighsts unless they are Xenon (the super-white lights as seen on Lexus, Mercedes, or the C6 Vette). My '04 has nice headlights, but still a little yellow-ish.
Do the '05's come with Xenon? I can't remember if they went from Crystalline in the '04 to jewelled in the '05 or vice versa. Oh well.....
rozett
• Limington, ME, USA
• Registered on 1/10/2003
• 163 posts
Posted:11/15/2004 06:52
And exactly what is the difference between 'jewelled' and 'crystaline' headlights anyway?
//bruce
birdman127
• baltimore, MD, USA
• Registered on 10/13/2002
• 581 posts
Posted:11/15/2004 17:29
05 headlights will fit but require cutting of the core support. The grill will not fit with out the bumper and the core support on the 05 should used on the install . I have seen costs around 1200 dollars for the grill, lights, core support, bumper brackets, and bumpers.
Moderator
2000 ltd 6.8 V10*4.30LS*
Lots of mods
check my gallery
rab986
• 34 posts
Posted:11/15/2004 18:42
I think I may go with the AIC lights....I think they look better than the 05 lights and I'm sure are way cheaper.
My UAV
J-Douglas
• 90 posts
Posted:11/16/2004 13:31
CORE SUPPORT.... that's the term I was forgetting when I posted on this thread. hahaha. Thanks Scott.
As for "crystaline" and "jewelled", it is just the style of headlight. I researched all the differences between the 04 and 05 when I went to purchased my EX, and found that the headlights were, in fact, different in appearance. But, if I remember correctly, the difference is just in appearance, and NOT function.
To be honest, and from what I gathered, I think the terms "crystaline" and "jeweled" JUST refer to the "look" or "style" the headlights have. Or, more precisely, the look or style of the reflective BACKING behind the bulb itself.
The change in headlight style was clearly noted on all Ford's dealer info lists for 2005, but I never got the vibe that the headlight itself was much different, other than its appearance. By this, I say that I never read where the 05 headlight went to Xenon or HID (as seen on Lexus and Mercedes). So, I would have a hard time justifying buying a whole new headlight assembly for a NEW headlight to shine JUST like the old one.
Is my information correct on the 05 headlight?
Does this all sound right?
edited 11/16/2004 13:33
rab986
• 34 posts
Posted:11/16/2004 15:31
Yes...everything you said coinsides with the research that I did yesterday and today. Exact same bulb, different physical appearance. So I think I will hold off on the headlight upgrade until I find a light that is actually an upgrade in functionality along with appearance.
My UAV
roger warden
• bethalto, IL, USA
• Registered on 11/13/2004
• 26 posts
Posted:12/28/2004 23:50
05 replacement lenses are probably going to be more expensive than aftermarket. Try here.
http://www.mytightride.com/foex20crhele.html
Posted:12/31/2004 10:28
Found them for $185.95 here: http://autosoundgear.com/tek9.asp?pg=products&specific=jqhmprc8
edited 12/31/2004 10:29
birdman127
• 581 posts
Posted:12/31/2004 11:31
Got ya beat Eric....How about 109+ 40 s+h...149.00 to your door
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6763&item=7944669135&rd=1
Moderator
Lots of mods
check my gallery
