Ford Excursion Forums > General Discussion > General Discussion
Another rotor question
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 590
Thai loto
• Los Angeles, CA, USA
• Registered on 11/20/2004
Posted:11/20/2004 15:18
Have a 2000 2WD excursion with ABS. I've grinded into my front left rotor and need a replacement ASAP. Has anyone ever tried the rotors that pep boys or autozone has? I do not really need cross-drilled or slotted rotors, since I've not really had problems with the stock ones and this is only for daily driving, but if the price is right, I may consider them too..
Doug Loper
• Byron Center, MI, USA
• Registered on 9/26/2003
• 114 posts
Posted:11/20/2004 20:56
I'm using Raybestos rotors. Superior to stock, but not as expensive as the slotted crossdrilled rotors. I got mine at a local parts place.
2000 X V-10
Mods: 6" Revtek lift
35" M/T Baja Claw Radials
16" x 10" Eagle Alloy Rims
SilverStar 9007
Clear front corners.
Posted:11/21/2004 16:49
You'll be just fine going through a parts store for rotors. Anything's better than your situation right now, that's for sure!
BTW, welcome to the site!
