Fuel 'Economy'
Thread Statistics:     Users to Post: 4   |   Total Posts: 5   |   Total Views: 690
pdgx
• Dunlap, IL, USA
• Registered on 3/6/2003
Posted:3/14/2003 15:04
So where is the limiting system that can be changed to increase fuel mileage - intake air, exhaust, ..... ??
Posted:3/14/2003 17:25
It all depends which engine you're referring to...V8, V10, or Powerstroke?
pdgx
• Dunlap, IL, USA
Posted:3/17/2003 07:10
The V8. Runs great - just needs a good tail wind.
Posted:3/17/2003 08:54
None of the above...
The problem really is weight. Reduce the weight & increase fuel efficiency.
I find it easier to just accept it. Anything else will drain your wallet...
try pumpin' up your tires. See if that helps a bit.
Raymond Golson
• Piscataway, NJ, USA
• Registered on 8/19/2002
• 68 posts
Posted:3/28/2003 07:31
Just took a road trip to sunny Florida (snow and cold starting to bug me), PSD, Limited, Goodyear 305x70x16, Monroe Reflex and air filter only changes and I got 690 miles to a tank going down with 48lbs of air in tires, pumped them up to 58lbs for the return trip, got 703 miles to a tank of gas... One stop going and coming, unheard of (for me)... Looking to add a chip before the next trip but as she sits now I got NO COMPLAINTS
Fuel 'Economy'
