V10 Gas Mileage
Thread Statistics:     Users to Post: 5   |   Total Posts: 15   |   Total Views: 2765
Andy Anderson
• Jacksonville, FL, USA
• Registered on 1/17/2005
• 77 posts
Posted:1/24/2005 19:58
Hey guys,
I just joined the club last week and have soaking up some of the great info all of you provide. It seems a consensus that 2000 rpm's, or around 66 mph, is the "sweet spot" for mileage. Once I started to pay attention to the tach in my 2000 X, 4WD, I noticed that at 2000 rpm's I am only running 59 mph. Is this something I should be concerned about? Idle problem? If anyone has a suggestion, let me know. It is great to be a part of this club. Andy
Scott Stover
• Fayetteville, NC, USA
• Registered on 4/16/2004
• 354 posts
Posted:1/24/2005 21:37
Depends on the rear end that your runnin, my 4:30's 2500-2700 @ 70 mph!! I hope that helps!
2000 X 4x4 V-10 4.3 LS
K&N
Gibson Catback
"Custom" Kickplates
Posted:1/24/2005 23:44
Hey guys,
Hi Andy,
What size tires are on your X? It's possible that they may be larger than stock and throwing off your speedometer reading.
2000 RPM is definitely the sweet spot. 65-70 MPH = 18-19 MPG in my diesel Excursion. Any faster and she starts going downhill...fast!
Andy Anderson
• 77 posts
Posted:1/25/2005 11:32
Don't know the rear end gear ratio, other than it is stock and recently recalibrated by Ford back to fact. specs after I took the 5.5 lift off and 35's. I am running the stock factory Firestone issued in the latest recall.
Andy Anderson
• 77 posts
Posted:1/25/2005 11:34
I am also having trouble getting my vehicle listed and photo on, the site says it is in my profile, but it never comes up.
Posted:1/25/2005 12:47
The smallest gear ratio you would have would be 3.73 (unless aftermarket gears were installed previously). I think Ford may have incorrectly calibrated your speedometer. It is clearly off.
Just click the "Join our club" link on the left-hand side of this page and it'll walk you through getting you and your vehicles listed in the club's member listing and vehicle registry!
Posted:1/25/2005 16:35
On second thought, maybe your speedo is correct...I forgot you had the V10.
Here's a pic of my Powerstroke X and the RPM at 75MPH. Approx. 2,250 RPM:
Andy Anderson
• 77 posts
Posted:1/25/2005 20:41
If I remember correctly, at 75 I may be at 2500 to 3000 rpm, that seems high to me.
Scott Stover
• 354 posts
Posted:2/17/2005 17:55
Here is my spedo and tach @ 70mph....V-10 4:30 LS rear!
K&N
Gibson Catback
"Custom" Kickplates
edited 2/17/2005 18:07
Scott Stover
• 354 posts
Posted:2/17/2005 18:10
Close up!
K&N
Gibson Catback
"Custom" Kickplates
V10 Gas Mileage
