Help with replacing parking/turn lamp
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 342
Posted:4/15/2005 17:08
I've just spent the last hour trying to figure out how in the hell to remove the parking and turn signal lamps from my '00 Excursion PSD. My parking/turn lamps are burned out on the passenger side so I've got the battery removed, washer fluid reservoir removed, 2 screws removed from the front of the parking lamp assembly...still nothing. I have no idea how this thing comes apart!
Anyone done this before that can shed light on this? Do I need to remove the headlight? What's the magic trick to get this thing removed??
edited 4/15/2005 17:09
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:4/15/2005 18:31
Eric it's just the 2 screws. it does have 2 pins that make it hard to pull work the top loose and the bottom will come out
Yahoo IM - kingsuv00
Posted:4/15/2005 18:53
Thanks Bill. CHPMustang helped me out as well on Instant Messenger. There are two screws underneath the parking light, remove 'em, then just pull out (towards you) on each side of the lamp assembly and it'll pop off of the rubber grommets. I'm all set. Thanks!!
edited 4/15/2005 19:07
Posted:4/15/2005 18:55
Superdeal there Eric that you got it knocked out
One of the IM's are always on
