tranny temp how to question
Thread Statistics:     Users to Post: 6   |   Total Posts: 10   |   Total Views: 578
badassxcursion
• chalfont, PA, USA
• Registered on 5/16/2005
• 25 posts
Posted:6/14/2005 20:42
I was hoping someone would beable to tell me is there an easy way to hook up my aftermarket tranny guage,I dont really feel like having to drill my pan to put in the sending unit(no factory guage)I heard there are t fittings that go in-line to the tranny cooler that have sending units in them....anyone ever heard of em'??or know an easy way to get it hooked up
Posted:6/14/2005 21:31
To install the sender on a 4R100 transmission (2000-2003) you'll utilize the test port plug on the lower drivers side of the tranny,here's a LINK from Daryl's site,he took some really good pics and explained it well
Posted:6/14/2005 22:08
Perfect timing. I think I'll tackle this when I flush my trans in the next couple of weekends.
gawent
• Registered on 3/2/2005
• 65 posts
Posted:6/15/2005 10:08
From the pix it sounds like the same as it is on the 04+ trannys. If it is, it is a piece of proverbial cake to install. I barely lost any fluid, just have the sensor ready to put in after you remove the plug. Instructions suggested using a liquid sealent instead of thread tape. The tranny guage is probably the easiest of the three guages to install. To me the nerve racking one was the pyro and having to drill into the up-pipe in a tight space
aobrien
• Winchester, VA, USA
• Registered on 6/3/2005
• 30 posts
Posted:6/15/2005 10:24
What is considered the "normal" operating range for the 4R100 tranny?
Andy
Ford_Forgotton
• I hate New Orleans, LA, USA
• Registered on 6/15/2005
Posted:6/15/2005 12:54
amazing where I find links to my webpage at Love that webtracking software!
If your flushing your tranny, I just posted my tranny flush pictures too
http://www.forgotton.net/diesel/transflush/index.htm
As for the temp of a 4r100, I like to see them under 200. You can take them as high as 220, but anything over that and you have problems.
I can get mine up to 180 running around town unloaded in 90 degree weather with lots of stop and go traffic. Once on the freeway, and the TC locked, it drops to like 150-160 pretty quick.
If your sitting right on the edge of 200 degrees, I would look into getting another cooler in-line with your factory coolers.
Daryl
2000 F-350 PSD CC SWB 4x4 XLT Lariat with LOTS of mods
edited 6/15/2005 12:55
Posted:6/15/2005 13:14
Welcome to the Ford Excursion forums Daryl! Great to have you aboard
Hope you don't mind me referring over to you as you have a great personal website which helps so many
Ford_Forgotton
Posted:6/15/2005 14:31
Nope, no problem. Thats what it is there for. And I dont pay for the bandwidth, so it doesnt hurt me any
Daryl
Posted:6/15/2005 14:46
OK Daryl, now that you've joined, you gotta great a few registry entries of your vehicles/ATVs. Yes, the pics are on your site, but you can link to your site from the registry entries.
I'll be checking out your tranny flush instructions, too.
Welcome aboard!
badassxcursion
• chalfont, PA, USA
• 25 posts
Posted:6/16/2005 19:35
Chp...Darryl thanks for the great info!!!!!!!!!!!!!!!
