Subwoofer box?
Thread Statistics:     Users to Post: 9   |   Total Posts: 20   |   Total Views: 2669
excursion_man
• Dallas, TX, USA
• Registered on 8/2/2002
• 53 posts
Posted:3/28/2003 12:39
Here are some examples...Overkill but examples.
http://www.sounddomain.com/member_pages/view_page.pl?page_id=300522&page=1
http://www.sounddomain.com/member_pages/view_page.pl?page_id=269230&make_type_query=make%3DFord&model_brand_query=model%3DExcursion&tree=Ford%20Excursion
http://www.sounddomain.com/member_pages/view_page.pl?page_id=168547&page=3
http://www.sounddomain.com/member_pages/view_page.pl?page_id=225222&make_type_query=make%3DFord&model_brand_query=model%3DExcursion&tree=Ford%20Excursion
Bill Johnson
• Rio linda, CA, USA
• Registered on 6/11/2002
• 201 posts
Posted:3/30/2003 20:23
I used bender board on mine and put two 15" subs where the spare goes they
rock.check out my superford page.-- http://www.superford.org/registry/vehicles/index.php?vID=1268
or my mobile audio world page. --
http://www.mobileaudioworld.com/mygallery.asp?id=3321
Yahoo IM - kingsuv00
Scott Coats
• Ft. Lauderdale, FL, USA
• Registered on 1/8/2003
• 84 posts
Posted:3/31/2003 10:00
I've looked at this issue in depth. Maybe my $0.02 will help...
I had planned to install two fiberglass enclosures in the barn doors for two 10" subs, but ended up (for now) with a Q-logic double box for them. Definitely (IMHO) need two 10"ers to fill the Excursion and a lot of power (I'm running 1200 watts to the two subs at ~1 Ohm). I lucked out and got the box and two Infinity subs on a close-out at Circuit City for $99, so I'm going to stick with them until I get motivated to play with the system again.
I bought two MDF enclosures made for the rear doors from a guy on eBay but never installed them in the rear doors because of the great deal I got from Circuit City. The rear door location is probably the best bet if you want a lot of bass (I'll sell the two enclosures for $60 plus shipping if anyone wants them).
JL Audio (http://www.jlaudio.com/stealthbox/excursion.html) makes a great single 10" sub enclosure that installs inside the center console, leaving a very shallow cubby hole for papers, etc at the top. It is not self-powered--you'll need an amp to drive it. Sounds great (a friend has it installed) but is pretty pricey at $575 plus labor. It also bounces the hell out of any drinks you have in the cup holders.
Q-Logic at one time planned to manufacture sub enclosures as I descibed above for the rear doors, but they never made it to market. They were listed on the web site last year, but no longer. A call to them last fall revealed that they have no plans to manufacture it since the Excursion is dead as of next year.
Hope that helps.
Weatherlite
• Mountain Home AFB, ID, USA
• Registered on 10/21/2002
• 133 posts
Posted:3/31/2003 12:26
This may be a stupid question, but what is bender board?
Bill Johnson
• 201 posts
Posted:3/31/2003 22:27
bender board is 3/8 mdf board with 1/8 score marks in it like tree bark. use it to rap around an object, then add layers to get your thickness. It also comes in 1/8 sheets as well. It's not sold in most home stores but any good wood shop can order it for ya.
Weatherlite
• 133 posts
Posted:4/1/2003 07:23
COOL! Thanks for the info. Sounds like it could be pretty useful in a lot of applications. May have to look into this stuff!
excursion_man
• Dallas, TX, USA
• 53 posts
Posted:4/1/2003 12:04
I have seen people use a circle router jig and cut 1" MDF into rings then glue/screw rings them together. This would be a waste of some wood though but would be very strong and relatively low cost.
Bill Johnson
• 201 posts
Posted:4/1/2003 21:22
I have done that too, it takes a lot more time,wood and, a lot more glue. Another idea is to make quarter circles 1" deep by 1" wide and interlock them then offset them. that too takes a lot of wood,time and, glue.
To add strength to your box buy a can of paint-on bed liner for trucks, it makes for a very strong box. my 2 subs push a max of 3500 watts each. that's quite a bit of pushing and pulling, also there are no standing waves in the box
Posted:4/2/2003 08:02
Scott,
Check your e-mail! I'm interested in your sub enclosures. The enclosures that Circuit City built into my rear "barn doors" are falling apart...I need a "fix" soon, my tunes just aren't the same anymore.
Jason Daniel
• Anchorage, AK, USA
• Registered on 6/14/2002
Posted:5/2/2003 00:09
That was me brother. 2 Nakamichi 10"s, but only in the left hand door. The right hand has an amp mounted to it. They do a great job of filling the entire cab. You can see them on my registry pictures. Just look for my name Jason Daniel and the truck's name.... "Tinkerbell." Hey, I didn't name her, she's my wife's truck. Anywho, it's a custom fiberglass enclosure but I wasn't around when they did it so I couldn't get any pictures of the process. All I can tell you is that they do a great job enhancing the entire sound system.
-Jase
Subwoofer box?
